Look at the "Fuel" section of the service manual (posted at the top of the DIY section) for info on how to remove the fuel sender. The fuel filter is the plastic mesh thing clipped to the bottom of the fuel pump in the picture below. It is removable and replaceable. The hardest part of the whole process is removing the cover of the fuel tank. Is is screwed on mighty tight and I didn't have the spanner tool, so I used a dead-blow hammer and a piece of oak to spin it off. However you remove it, avoid the use of ferrous metal tools to prevent sparks.
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| Replacing fuel filter | duke_afterdeath | Middle East | 28 | 07-12-2010 04:26 AM |
| Change to high quality filter lead to drastic drop in fuel efficiency | lh59 | DIY / Maintenance / Service | 19 | 07-02-2009 02:22 PM |
| Fuel Filter | abbeyaris | General Yaris / Vitz Discussion | 35 | 03-22-2009 11:40 AM |
