Originally Posted by CTScott
Look at the "Fuel" section of the service manual (posted at the top of the DIY section) for info on how to remove the fuel sender. The fuel filter is the plastic mesh thing clipped to the bottom of the fuel pump in the picture below. It is removable and replaceable. The hardest part of the whole process is removing the cover of the fuel tank. Is is screwed on mighty tight and I didn't have the spanner tool, so I used a dead-blow hammer and a piece of oak to spin it off. However you remove it, avoid the use of ferrous metal tools to prevent sparks.
Attachment 39578
Attachment 39579
hi thanks for this info on the fuel filter but i can not find the service manual you are talking about can you please help.?
