If you used the terminal on the under dash fuse panel for your keyless entry, that same point would be fine for the window power. That tap point is a 60A capable supply, so you can use a female spade terminal that can accept 12 AWG wire and then connect two separate in-line fuse holders to it. I have my remote starter, my heated seats, and my power hatch popper all connected there with four separate fuses.
#2 | |
![]() ![]() ![]() Drives: Black 07 Toyota Yaris Sedan Join Date: Oct 2009
My seat heaters are ignition switched as well. You tap that point for the high power feed and then use a relay to switch it with the coil connected to the pink wire on the ignition switch.
oh i see. I'm pretty sure i got a good idea of what your talking about. Thanks Scott!
| Ohm's Law and Setting Amp Gain | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 24 | 03-13-2012 09:34 PM |
| Keyless Entry on Yaris w/o power locks question | rhumphrey205 | DIY / Maintenance / Service | 4 | 12-03-2011 06:46 PM |
| Question about air conditioning power consumption | voodoo22 | General Yaris / Vitz Discussion | 15 | 09-21-2007 12:14 AM |
| Power Windows Leg Room | nwdixieboy | General Yaris / Vitz Discussion | 9 | 04-06-2006 07:19 AM |
