Old 08-17-2012, 10:36 PM   #1
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Originally Posted by tooter View Post
Can you let me know how much you charge for the privelege of selling here so that I can factor that cost into the selling price of the kits and manifolds?
Like Garm said, it's all a matter of signing up as a vendor and paying your monthly fee (which is around $60 IIRC).
Old 08-18-2012, 12:56 AM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Can you tell me where I can find the link?
Old 08-18-2012, 05:29 AM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
YGPM
Old 08-18-2012, 04:19 PM   #4
tooter
play every day
tooter's Avatar
Thanks, tk... I'll sign up when I'm ready to sell.
Thanks to Garm stocking a 90 degree silicon coupling, I now have an intake that fits the tooter perfectly...
It's an ESRI... Extremely Short Ram Intake.
Even though that filter is way oversized and difficult to fit into that small space I didn't want to lose it because that would also mean having to lose the velocity stack.
Hey Malibu...
If you use a smaller filter, it won't be nearly as difficult to come up with an intake. I just wasn't going to give up using that really cool velocity stack no matter what, so I made it work. A CAI would be even easier for you to fabricate because the cramped space would not be a factor since the pipe would be going into the fenderwell anyways.
So the ingredients to make this intake are:
Weapon R Dragon Short Ram polished aluminium intake tube, cut in half
BLOX 2.5" x 6" Velocity stack, mounting flange cut short
BLOX dry 6" matching dry element air filter
black 2.5" 90 degree coupling, ends trimmed short
black 2.25" straight coupling, trimmed short
These make a smooth flowing very low restriction intake.
I specifically chose the Weapon R tube because the MAF sensor mount is very close to the throttle body, and so could allow for severe cutting while still retaining its operational integrity.
I'll go install it now and post a pic of it on the engine.
Old 04-17-2013, 09:00 PM   #5
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Dragging out an old post from page 38-ish to ask a few questions.
- Could you use the stock MAF tube instead of chopping the Weapon R?
- How does the quality of the BLOX compare to other less expensive kit, e.g. the stuff at AutoZone/AutoValue/NAPA/etc?
- Does having the stock MAF on a 2.5" tube cause issues? I was told (on these forums) that the slower air velocity in a larger diameter tube would lead to wonky behavior from the ECU. I'm assuming you haven't had issues to this point, yes?
Old 04-17-2013, 09:45 PM   #6
tooter
play every day
tooter's Avatar
Sure. Why not?
No, it wouldn't work because the Weapon R intake tube adapts the 2.5 BLOX velocity stack to the 2.25 throttle body flange. And second, the rubber intake tube isn't rigid enough to support the freestanding stack and filter...
I don't know about any of the other stuff, but BLOX is first rate. The intake profile is parabolic, and is complete to 180 degrees. It's a beautifully simple practical design...
I especially like the BLOX dry filter as it has no oil issues. It perfectly seals the stack and removes instantly and easily for cleaning.
Nope, no issues whatsoever.
This is because the tube the MAF is in is 2.25". You can see the reduction in diameter takes place in front of the MAF.
You were told correctly. The intake diameter can be anything you want upstream...
...as long as it reduces down to the proper 2.25 diameter where the air flows over the MAF.
Since I'm here, I took a whack at grinding one of the runner entrances. The amount of weld I can remove is limited so as not to weaken the manifold, but at least I was successful in removing the protruding weld swirls as I'm sure they cause turbulence right at the critical point of entry. I was also able to open up the entrance a bit wider for a freer flow.
This is before for contrast...
Old 04-18-2013, 03:22 PM   #7
jetblast
Drives: Gen 1 XB
Damn that Blox venturi is sexy. Smoooooooth flow!!!
Why strive for a JDM BB, when you can promote the Scion badge?
jetblast is offline   Reply With Quote
Old 04-18-2013, 05:30 PM   #8
CrankyOldMan
So if the air all has to flow through the narrower section, doesn't it negate the larger diameters in front of/behind the MAF? I haven't done fluid mechanics yet, so I'm just going off what I've read/heard/seen.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
