Old 04-17-2013, 09:00 PM   #11
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Originally Posted by tooter View Post
So the ingredients to make this intake are:
Weapon R Dragon Short Ram polished aluminium intake tube, cut in half
BLOX 2.5" x 6" Velocity stack, mounting flange cut short
BLOX dry 6" matching dry element air filter
black 2.5" 90 degree coupling, ends trimmed short
black 2.25" straight coupling, trimmed short
These make a smooth flowing very low restriction intake.
I specifically chose the Weapon R tube because the MAF sensor mount is very close to the throttle body, and so could allow for severe cutting while still retaining its operational integrity.
Dragging out an old post from page 38-ish to ask a few questions.
- Could you use the stock MAF tube instead of chopping the Weapon R?
- How does the quality of the BLOX compare to other less expensive kit, e.g. the stuff at AutoZone/AutoValue/NAPA/etc?
- Does having the stock MAF on a 2.5" tube cause issues? I was told (on these forums) that the slower air velocity in a larger diameter tube would lead to wonky behavior from the ECU. I'm assuming you haven't had issues to this point, yes?
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
