Old 12-28-2012, 12:37 PM   #1
Autocross72
Drives: 2009 3rd Polar white
Are you going to Dyno it with the 1ZZ throttle body? That is the throttle body that this intake was designed for, so I would bet you would see some gains in hp and torque. If you do see gains, I would bet that you could sell a lot more of those manifolds.
Autocross72 is offline   Reply With Quote
Old 12-29-2012, 12:10 AM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I don't think I'll be dynoing it with a 1ZZ as I'm more of an economy driver than a performance one. The manifold is not only designed for the 1ZZ throttle body, it was also designed for a 1.8 engine so I don't think it would make that much difference in an normally aspirated application. However, a forced induction situation would be a completely different story. Even at the tooter's best +4hp at 5,600rpm that isn't nearly enough to be detected in actual driving. And remember that's at wide open throttle. Most driving is at partial throttle, where the difference between the tooter and stock manifold is too slight to feel. We've been running it on our daily driver Yaris for over 2,000 miles now and it works just fine. And the stock air box really quiets down the intake.
Old 12-30-2012, 08:43 PM   #3
tooter
play every day
tooter's Avatar
Speaking of dyno runs, here's a video of the tooter...
http://www.youtube.com/embed/DdQZcHXtnTI
Old 12-31-2012, 04:30 AM   #4
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
You're killing me here, man. You've come so far that not sourcing a 1ZZ TB and dynoing it seems weird to me, like you're aborting the project early. You even had the TB adapter made to match the 1ZZ throttle body, yet you aren't going to at least try and get one?
4/20 NEVER FORGET is offline   Reply With Quote
Old 12-31-2012, 11:53 AM   #5
tooter
play every day
tooter's Avatar
Ok, I'll get one and dyno it even though that wasn't the goal.
Making the tooter fit both throttle bodies without any extra parts was an afterthought so that I wouldn't have to stock 2 adaptors. In fact it actually fits three, the stock 51mm three bolt cable controlled throttle body.
I still think that the results will be similar as these back to back runs (stock:red tooter:blue) done on the same day...
the stock engine is only capable of taking in so much air/fuel.
Old 01-03-2013, 11:41 AM   #6
4/20 NEVER FORGET
Back when I worked on Hondas, when we would swap intake manifolds, whenever possible we would include whatever the largest stock throttle body that would fit the manifold. I think we have a similar case here, while not a huge bottle-neck, it's a bottle neck to the system, and you did make the adapter to fit the larger throttle body.
I'm sorry if I came off harsh at all in my last post, I've enjoyed this thread and your tinkering that has led you to where you are. It's a good looking manifold, and it was designed for a larger throttle body than that which you are using, and it's an easy swap to the larger 1ZZ. You have to at least try :) I think there are many others who are following the thread that are also very interested. I think with the change will come more tinkering, and more content too. I appreciate the informative posts.
Old 01-03-2013, 03:24 PM   #7
tooter
play every day
tooter's Avatar
Hey Never,
No offense taken. I just got this 1ZZ 0D030 throttle body off ebay today...
...and will be running it soon. I read through the whole 1ZZ thread, and it looks like a real pain in the ass to get working half way decently with all the floating idles, wildly racing rpms, stripped screws, and repeated check engine lights. Hopefully, I can avoid some of the pitfalls knowing the experiences others have gone through.
I at least have some advantages over trying to make it work with the plastic stock manifold. The Corolla manifold was originally engineered for a 1.8 throttle body, and the tooter adaptor I designed will fit it perfectly.
I'll let you know exactly how all this shakes out.
Old 01-10-2013, 06:17 PM   #8
tooter
play every day
tooter's Avatar
THANK YOU!
Old 01-10-2013, 08:02 PM   #9
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
THANK YOU!
Awesome read!
JustDidIt is offline   Reply With Quote
Old 01-11-2013, 03:13 PM   #10
4/20 NEVER FORGET
THANK YOU!
No dude, THANK YOU!!! I am so happy you got it running good finally, and that there seems to be a noticeable difference. Looking at the two throttle bodies side by side, you would think there would have to be. The stock TB is so small!
Anyways, this has been a great thread to follow, and I know I can speak for the entire community when I say thanks for posting so often and clearly about the issues and wins you have been having. These threads help us all out. Again, congrats, and I can't wait to see what this sucker does on the dyno. Please post a vid with audio! I bet she screams!
Old 01-11-2013, 06:09 PM   #11
jetblast
Drives: Gen 1 XB
Staring at pic............................................... .................................................. .................................................. .................................................. .................................................. .................................................. ...........still staring at pic............................................... .................................................. .................................................. .................................................. .......damn nice.............................................. .................................................. .................................................. .................................................. .......still staring.
Why strive for a JDM BB, when you can promote the Scion badge?
jetblast is offline   Reply With Quote
Old 01-11-2013, 07:11 PM   #12
tooter
play every day
tooter's Avatar
Hey man, thanks for the kind words...
From this experience I'm pretty certain that the chips don't even need to be swapped. The butterfly just needs to close farther so that the ECU can find the right idle. Because when I ran both chips, both had the same symptoms. Reducing the idle speed alone is what resolved all of the issues.
So in the future...
If anyone wants to install a part number 030 Corolla 1ZZ throttle body on their 1NZ engine, don't mess with the chips, and simply turn the idle down by backing out the little idle adjustment screw counterclockwise one turn using a 5/64th inch hex key... and everything should work just fine.
I did quite a bit of driving today on the freeway and in traffic with shopping and running errands, and I'm so thoroughly pleased with how well the engine responds with the bigger throttle body.
It behaves like a completely different car!
Old 01-11-2013, 07:15 PM   #13
JustDidIt
JustDidIt's Avatar
Wonder if this works on my 1NZ-FXE....
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
