#937 |
![]() Drives: 2009 3rd Polar white Join Date: Apr 2011
Are you going to Dyno it with the 1ZZ throttle body? That is the throttle body that this intake was designed for, so I would bet you would see some gains in hp and torque. If you do see gains, I would bet that you could sell a lot more of those manifolds.
#938 | |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
#939 |
play every day
#940 |
Awe the video ends just before the climax!
#941 |
play every day
#942 | |
![]() ![]() Drives: 2008 Yaris HB MT Join Date: Jan 2009
#943 | |
play every day
![]() Making the tooter fit both throttle bodies without any extra parts was an afterthought so that I wouldn't have to stock 2 adaptors. In fact it actually fits three, the stock 51mm three bolt cable controlled throttle body. I still think that the results will be similar as these back to back runs (stock:red tooter:blue) done on the same day... ![]() the stock engine is only capable of taking in so much air/fuel. Last edited by tooter; 12-31-2012 at 01:47 PM. |
#944 | |
#945 |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
Holly Sh..t, haven't checked this thread for a while..
Am I dreaming or this (part in the middle) is what I need to install my Xb/Echo Blitz Sc on my Yaris? |
#946 | |
play every day
![]() ![]() Here's how you can find out for sure... The three manifold bolts form a triangle with sides of 57mm, 71mm, and 75mm... and the four throttle body stud holes are 60mm square. |
#947 |
^ Thanks
I am getting 71, 75 and 67 mm (instead of 57 that you indicated) with 46 mm internal hole diameter. I suspect you have 67 mm in your picture as well (Judging by the gasket in your pic). My TB bolts measure 60 mm, 60 mm, 60 mm, 60 mm. Can you pls double check this 57 vs 67 mm issue as well as the internal diameter of the hole? |
#948 | |
play every day
![]() The center hole is 5mm larger than yours is. It's 51mm which was designed to exactly match the Corolla 1.8 manifold. That would mean a 2.5mm forward facing lip on the inner diameter of your manifold which should be flared out with a hand file or Dremel to create a smooth transition. With the adaptor bolted on, a sharp scribe could be run around the inside circumfrence to exactly mark the lip so that you'd know exactly what to remove. Aluminium is really soft and works easily. You'd also want to be sure that the throttle body butterfly tips in at the right attitude so as to clear the screen on the O ring gasket. Although with forced induction, I'm not really sure that screen would matter and could simply be clipped off if it was a problem.
#949 |
^ Thanks
#950 | |
I'm sorry if I came off harsh at all in my last post, I've enjoyed this thread and your tinkering that has led you to where you are. It's a good looking manifold, and it was designed for a larger throttle body than that which you are using, and it's an easy swap to the larger 1ZZ. You have to at least try :) I think there are many others who are following the thread that are also very interested. I think with the change will come more tinkering, and more content too. I appreciate the informative posts. |
#951 | |
play every day
![]() No offense taken. I just got this 1ZZ 0D030 throttle body off ebay today... ...and will be running it soon. I read through the whole 1ZZ thread, and it looks like a real pain in the ass to get working half way decently with all the floating idles, wildly racing rpms, stripped screws, and repeated check engine lights. Hopefully, I can avoid some of the pitfalls knowing the experiences others have gone through. I at least have some advantages over trying to make it work with the plastic stock manifold. The Corolla manifold was originally engineered for a 1.8 throttle body, and the tooter adaptor I designed will fit it perfectly. I'll let you know exactly how all this shakes out.
#952 | |
#953 |
play every day
Hey Garm,
![]() What's a servo, and how do you swap it? Is that what was being referred to as a "chip"? There were so many different proceedures with wildly varying and inconsistent results it was truly mind bending just trying to make it through that long thread. ...and, by the way, is there anyone here who is actually running a normally aspirated 1ZZ throttle body that works properly? I'd love to hear from you how you did it. |
#954 |
^ yeah, it's that black plastic end piece that is attached with rivets. You drill them out, and swap them so your 1NZ one is on the 1ZZ throttle body. You'll need some small screws or bolts with nuts to install.
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
