![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
PCV Valve Replacement
Hey guys. So the other day I was reading around about regular maintenance and I realized I never had the PCV valve looked at.
I pulled off the hose and immediately noticed oil on the end of the tip. After taking the valve off, I noticed the inside pretty dark, which is normal. However, the metal sliding mechanism did not sound good. The replacement PCV I received from Toyota clicked rapidly if you shook it, while the old one clicked only once or twice, so it seemed pretty gunked up. I'm sure those of you with an oil catch fair better, but I am at 160,000km without one so this was a good investment. The idle also seems to be better, not sure if it is placebo but I swear it's smooth as butter now and not jumping from 500-800rpm. BTW it cost me $18 CAD at the dealer ... rip off and a half if you ask me, but I wanted a genuine part. |
![]() ![]() Drives: NONE Join Date: Oct 2008
I replaced my 2002 Echo PCV Valve with a NAPA Echlin for $7.10. I consider NAPA Echlin to be at least as good as OE, if not better.
I just take mine out and clean it with carb cleaner every 20k miles or so to keep it running smooth and good. Might change it at 100k just as preventative maintanance.
Ya I think I will start cleaning it out when I change my air filter. It seemed pretty gunked up.
![]() ![]() Drives: 07 Yaris Join Date: Dec 2009
Where is the PCV located? Could anyone do a quick DIY on the location and the steps involved locating and removing?
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
SIPNDEW
take off the vvti cover on your engine. underneath that is the valve cover. on the drivers side of the valve cover there is a hose going into the back right corner that attaches to a fitting screwed into the valve cover. that fitting is the pcv valve. with the proper size wrench or maybe an adjustable you can remove it.
You need a 19mm deep socket to remove the PCV valve.
When I replaced mine I also put some anti-seize on the thread, since taking the original off took some force with breaker bar. Should make it easier the next time around. Takes about 10 mins to replace. |
Thanks for the explanation are there any photos to clarify more?
I love momentum.
What is the normal service interval on the PCV valve?
I found and removed the PCV Valve and cleaned it, checked it, and replaced it!
A lot easier than I thought. This Forum is the greatest.
![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
Just replaced mine today, old one had a bit of buildup on it. Seems like the new valve threads in a bit easier than the factory one too, tightened it snug but not very tight. Not sure if you can hurt the valve or engine by trying to make it very tight.
I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important. |
Yeah actually I just ordered a replacement, that time of year again to replace it (cheap insurance).
Cleaned mine today though it really didn't need it. Thanks for posting the reminder.
![]() Drives: toyota yaris 1.0 t3 2004 Join Date: Feb 2013
anybody having pictures to show the location n replacement of pcv valve with pics.
Toyota yaris 1.0 2004 |
#17 | |
![]() ![]() Drives: 08 Yaris AT, 350Z GT MT Join Date: Feb 2013
http://www.yarisworld.com/forums/showthread.php?t=43903 |
How do you know the PCV valve may need replacing or cleaning? Does the engine idle or run a particular way? My engine idles rough and oscillates badly when either in drive or a/c on in drive; when in neutral, it idles smoothly. I would like to know before the check engine light comes on.
Thanks for any extra thoughts on this, Pat |
| PCV valve question | window_lee | DIY / Maintenance / Service | 31 | 10-22-2014 04:05 PM |
| Valve Noise | barryware | DIY / Maintenance / Service | 25 | 02-13-2013 02:39 PM |
| Two different PCV valve Part#s for Yaris? | auxmike | DIY / Maintenance / Service | 6 | 03-18-2011 08:55 AM |
| PVC valve routine? | N9QGS | DIY / Maintenance / Service | 13 | 05-26-2009 07:32 PM |
| 2007 Yaris LB - Valve Adjustments | Pavel Olavich | DIY / Maintenance / Service | 3 | 03-30-2007 05:34 PM |
