#109 |
I have no idea why he would say that, as it is genuine OEM stalk. The only thing that might have made him question it is the horn wire, which I add, to save people the hassle of breaking the pin to pull their's out of the original connector.
#110 |
![]() Drives: HDS Join Date: Jun 2013
Hello CTScott
I write from another part of the world “italy” I are desperate ![]() I know that we are talking only of yaris but you are the experts on Cruise Control that I found I own a hybrid Auris HSD 1,8L I put all the parts needed as the model with the standard Cruise Control when I press the button on/off, the lights Cruise Control lights up green but just release the brake I get a yellow triangle and the following “check Cruise Control “ do you have any advice for me??? ![]() thanks so much in advance foto http://tinyurl.com/nfsms5n |
#111 | |
#112 |
OK
good vacation we update when you return Isidoro north italy |
#113 |
while visiting europe
if you go to Northern Italy I'll pick you?? I am close to Bergamo, which has the largest airport where land all European flights Bye-Bye! |
#114 |
![]() ![]() Drives: toyota Join Date: Feb 2011
do u have anymore?
#115 |
I am a bit more North: England, Denmark, Sweden, Estonia and Russia.
#116 |
#117 |
![]() Drives: Toyota Yaris 2010 Join Date: Jul 2013
Do you have more? :)
#118 |
#119 |
Will it work on european Yaris 2010?
#120 |
![]() Drives: 2007 white hatchback Join Date: Apr 2013
Was reading thru a few treads, seems your saying that all yaris have the hard wiring from the factory, correct? I have a 07 hatchback auto trans. If all i need is this kit your selling i'd like to purchase one, if you still have some available. Pay pal ok? Thanks Bruce
#121 |
![]() Drives: 08 base Hb Join Date: Apr 2009
I'm interested in one as well if still available. Will be for an 08 liftback 5spd
#122 |
My understanding is no, but a person from Germany recently ordered one from me, as he was told that it would work. I will let you know when I hear back from him.
#123 |
Number of the ECU is : 89661-0dd90
Hope it can work :) Would be nice |
#124 |
It looks like the car already has the clutch switch installed, i cannot have it started when the clutch is not pressed... So i guess that one is installed...
#125 |
The cruise control clutch switch is different. The starting one requires the clutch to be pressed completely to trigger, where the cruise control one triggers as soon as the clutch switch is touched.
#126 |
ah alright, didn't know that, thanks :) are there ways to check if the car is prepared for cruise?
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| Cruise control install 2009 Yaris 3 door | PeteZNY | DIY / Maintenance / Service | 125 | 03-31-2024 09:22 AM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Can we do this? (aka The DIY Cruise Control Thread) | mrbond | DIY / Maintenance / Service | 502 | 07-22-2017 02:57 PM |
| This is pretty frikken stupid - Yaris '07 LB auto cruise control | firemachine69 | DIY / Maintenance / Service | 10 | 07-20-2010 08:09 AM |
