Old 08-05-2013, 12:05 PM   #1351
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Originally Posted by tooter View Post
Took it for a long drive up north on the 5 freeway (65-80mph) and up to Mt. Pinos and got 42.6 mpg in 248 miles.
It's ready to dyno now, so when work allows I'll be off to Harry's shop.
How does that compare to other combos that you have run on that car?
Old 08-05-2013, 10:29 PM   #1352
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
These are the statistics so far...
1,931 miles with the stock intake manifold got an average of 35.9mpg.
5,592 miles with the tooter got an average of 36.4mpg
(although that included a full winter of cold weather driving which always yields lower mileage)
248 miles with the tooter et got an average of 42.6mpg
(although that was just one fillup with a lot of high speed freeway miles)
The best prior fillup was 39.1mpg.
(with freeway driving)
I'll post more mileage figures when I rack up enough to be able to get an accurate indicator. And I'll be down at Harry's dyno shop as soon as I can find a break from work.
Old 08-05-2013, 10:31 PM   #1353
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
The mileage increase is astonishing
Old 08-05-2013, 10:52 PM   #1354
tooter
play every day
tooter's Avatar
Well, remember that was just one long trip, and most of it was between 65mph and 80 mph. It'll settle down to a more reasonable average in a little while.
I can say this. The engine runs really good on the freeway, and if I had to hazard a guess why, it would be porting the mouths of the runners. Those rough welds were really overhanging the intakes.
The dyno will tell the tale.
All the bullshit ends there.
Old 08-06-2013, 01:54 AM   #1355
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
This is making me think that the 1NZ could benefit from longer intake runners...than oem. Let see what the DYNO says and some more daily driving testing. :)
BTW.. Awesome!
JustDidIt is offline   Reply With Quote
Old 08-06-2013, 02:57 AM   #1356
tooter
play every day
tooter's Avatar
BTW.. Awesome!
Thanks, man.
It's fun experimenting just to see what will happen. The tooter's runners are one inch longer than stock, which is only 5% longer. However, they are oriented completely different than the stock runners in that they look directly at the throttle body like an exhaust header...
Old 08-14-2013, 12:19 AM   #1357
Bluevitz-rs
No updates yet I guess...
Old 08-14-2013, 02:42 AM   #1358
tooter
play every day
tooter's Avatar
Sorry, Blue.
I've been distracted with developing another tooter product...
And just got the prototype running on my truck today...
It made the intake runners 12% longer and really lowered the torque curve. I can slip the clutch in first gear with no gas pedal and the truck doesn't stall out even down to just 400rpm.
The Yaris is running great...
...and It'll be on the dyno soon after we drive it a while to make sure everything gets settled in.
Old 08-14-2013, 09:14 PM   #1359
tooter
play every day
tooter's Avatar
I cut about half of the bend off of the slilcone coupling to straighten the intake because the air filter didn't need that much bend. So it's all ready to run...
Just called Harry...
...dyno test is on for Saturday.
Old 08-14-2013, 10:03 PM   #1360
Cool!
Old 08-14-2013, 10:26 PM   #1361
tooter
play every day
tooter's Avatar
...and the Tacoma hits the dyno next week if I can find the free time.
I already did the baseline dyno, so the next one will be with the tooter II.VII.
Old 08-15-2013, 07:15 PM   #1362
Viperoni
Drives: 2005 Toyota Echo
Sweet!
2006 Saturn Ion Redline
Old 08-17-2013, 05:41 PM   #1363
tooter
play every day
tooter's Avatar
On the dyno, the tooter et didn't perform any better than the regular tooter, but it didn't perform any worse either. With 111hp and 105tq the graphs are basically the same. So for all my tinkering around, I didn't actually change anything!
Old 08-17-2013, 06:53 PM   #1364
etherdude
Drives: 2012 Yaris SE 5-speed
thanks for the data...
Tooter, please remind us. How do your fully modded figures compare with "bone stock"?
Thanks, Doug
etherdude is offline   Reply With Quote
Old 08-17-2013, 07:13 PM   #1365
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
While it's disappointing to see that there isn't an appreciable improvement, it's certainly unique. Have you considered changing the runner length on a "standard" tooter for comparison?
Old 08-17-2013, 07:38 PM   #1366
tooter
play every day
tooter's Avatar
Thanks, Doug
Here's bone stock dyno runs from the dyno chart sticky thread:
The results.
Stock:
91hp
91tq
Tooter:
111hp
105tq
So with:
Intake
Throttle body
Intake manifold
Header
Axle back exhaust
I have 22% more horsepower, and 15% more torque with the stock ECU, no tuning, and regular 87 octane pump gas. Latest gasoline fillup today: 39.4 mpg.
Total cost: $1,350
Old 08-18-2013, 11:17 AM   #1367
tooter
play every day
tooter's Avatar
I'd also add that none of these modifications has altered the basic reliability economy or longevity of the engine. My wife's car is still just a regular daily driver that always needs to be in service.
Now it's just way more fun to drive...
Old 08-18-2013, 02:04 PM   #1368
etherdude
Impressive results!
Tooter,
I would estimate you have optimized the volumetric efficiency of this particular air pump. A gain of 20 hp at the wheels is awesome. Without changes to cam timing, fuel map, and injectors (meaning access to the ECU), I cannot imagine there is anything left in a naturally aspirated Yaris. Think about it...your at the crank hp is pushing 125+.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
