Old 08-01-2013, 10:49 AM   #1333
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Is it done yet?
Old 08-01-2013, 11:30 AM   #1334
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
The welder might be done with it as soon as today...
I'm not even going to clean it up, it goes right on the car to find out if it will actually work.
edit: Just called the welder and it'll be done this afternoon!
(yipee )
Old 08-01-2013, 03:16 PM   #1335
Flipper_1938
Old 08-01-2013, 06:01 PM   #1336
tooter
play every day
tooter's Avatar
Hey Flip...
Just picked it up!
My wife is using the car today so I can't put it on yet. But tomorrow morning it'll be on the engine and I'll be driving it.
Greg
Old 08-01-2013, 07:20 PM   #1337
tooter
play every day
tooter's Avatar
Since I had the time, all of the welds got a quick bead blast to normalize the surface...
Old 08-01-2013, 08:07 PM   #1338
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
That looks awesome!! I need to make a trip up to LA and come check the work out in person....
JustDidIt is offline   Reply With Quote
Old 08-01-2013, 10:23 PM   #1339
Viperoni
Drives: 2005 Toyota Echo
Lookin good, can't wait for the driving report tomorrow!
2006 Saturn Ion Redline
Old 08-01-2013, 10:50 PM   #1340
tooter
play every day
tooter's Avatar
It should work just fine since Toyota had already put the same design on their cars...
I haven't been able to find this manifold in the US. However, it was installed on 1998 Toyota Starlets in the UK and in Pakistan.
I'd love to find one and see if the tooter flange would fit onto it, because building the tooter et took a lot of work.
Old 08-02-2013, 02:22 AM   #1341
tooter
play every day
tooter's Avatar
Let me know when you'd like to visit. That would be fun.
Greg
Old 08-02-2013, 10:46 PM   #1342
tooter
play every day
tooter's Avatar
Got the tooter et up and running this morning...
I messed up a little on the attitude of the throttle body as the rotation is about 30 degrees off, but it's not enough to keep it from working.
Drove it only a little bit today because of work, and it drives really good even with ECU just relearning the new operating parameters. It's just as quiet as stock in regular driving, but makes a really cool swooshing bwwwaaa sound when you step on the gas pedal. I think that's because there are no baffles in the plenum like there are in the regular tooter. And also I did a lot of porting on the mouths of the runners so that they are way more open and less restrictive than they were before.
I'm going to drive it around until everything is acclimated and then put it on the dyno, as that's the most trustworthy indicator of any changes.
Old 08-03-2013, 07:14 AM   #1343
Flipper_1938
Old 08-03-2013, 08:03 AM   #1344
Silver Streak
Silver Streak's Avatar
Drives: 2010 Yaris sedan silver
k&N Pannel air filter
Trd Exhaust
Trd Rear Sway Bar
Silver Streak is offline   Reply With Quote
Old 08-03-2013, 09:43 AM   #1345
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Oops, I guess you could cut it off again and have it rewelded.
Old 08-03-2013, 09:49 AM   #1346
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
relocate the battery or get a capacitor style battery like CTScott is experimenting with and it will be gravy.
Old 08-03-2013, 11:55 AM   #1347
^ A small dry cell battery would work great, that's what I use in my cars. Mine weighs 4 pounds.
Way to go, tooter
Old 08-03-2013, 12:21 PM   #1348
tooter
play every day
tooter's Avatar
That's exactly what I'm going to do. It's a small issue and simple to resolve. That's the beauty of aluminum. It's easy to work with. But before I do that, first I want to drive it around and then put it on the dyno, because rotating the throttle body is only for aesthetics and isn't going to make any difference in how it runs.
Old 08-05-2013, 09:47 AM   #1349
JustDidIt
JustDidIt's Avatar
Can't wait to hear the audio of the intake!
Old 08-05-2013, 11:41 AM   #1350
tooter
play every day
tooter's Avatar
Took it for a long drive up north on the 5 freeway (65-80mph) and up to Mt. Pinos and got 42.6 mpg in 248 miles.
It's ready to dyno now, so when work allows I'll be off to Harry's shop.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
