#1333 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
Is it done yet?
#1334 |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
The welder might be done with it as soon as today...
![]() I'm not even going to clean it up, it goes right on the car to find out if it will actually work. edit: Just called the welder and it'll be done this afternoon! (yipee )
#1335 |
#1336 |
play every day
Hey Flip...
![]() Just picked it up! ![]() ![]() ![]() My wife is using the car today so I can't put it on yet. But tomorrow morning it'll be on the engine and I'll be driving it. ![]() Greg |
#1337 |
play every day
Since I had the time, all of the welds got a quick bead blast to normalize the surface...
#1338 |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
That looks awesome!! I need to make a trip up to LA and come check the work out in person....
#1339 |
![]() ![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Aug 2010
Lookin good, can't wait for the driving report tomorrow!
2006 Saturn Ion Redline 2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold 2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped |
#1340 |
play every day
It should work just fine since Toyota had already put the same design on their cars...
![]() ![]() I haven't been able to find this manifold in the US. However, it was installed on 1998 Toyota Starlets in the UK and in Pakistan. ![]() ![]() ![]() I'd love to find one and see if the tooter flange would fit onto it, because building the tooter et took a lot of work.
#1341 |
play every day
#1342 |
play every day
Got the tooter et up and running this morning...
![]() ![]() I messed up a little on the attitude of the throttle body as the rotation is about 30 degrees off, but it's not enough to keep it from working. Drove it only a little bit today because of work, and it drives really good even with ECU just relearning the new operating parameters. It's just as quiet as stock in regular driving, but makes a really cool swooshing bwwwaaa sound when you step on the gas pedal. I think that's because there are no baffles in the plenum like there are in the regular tooter. And also I did a lot of porting on the mouths of the runners so that they are way more open and less restrictive than they were before. I'm going to drive it around until everything is acclimated and then put it on the dyno, as that's the most trustworthy indicator of any changes. |
#1343 |
#1344 |
![]() ![]() Drives: 2010 Yaris sedan silver Join Date: Jul 2012
k&N Pannel air filter Trd Exhaust Trd Rear Sway Bar |
#1345 |
Oops, I guess you could cut it off again and have it rewelded.
#1346 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
relocate the battery or get a capacitor style battery like CTScott is experimenting with and it will be gravy.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#1347 |
^ A small dry cell battery would work great, that's what I use in my cars. Mine weighs 4 pounds.
![]() Way to go, tooter
#1348 | |
play every day
#1349 |
#1350 |
play every day
Took it for a long drive up north on the 5 freeway (65-80mph) and up to Mt. Pinos and got 42.6 mpg in 248 miles.
![]() It's ready to dyno now, so when work allows I'll be off to Harry's shop. |
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
