Old 07-21-2013, 12:13 PM   #127
Originally Posted by Jadijkstra2000 View Post
ah alright, didn't know that, thanks :) are there ways to check if the car is prepared for cruise?
The best test is to check the voltage on pin 40 of the A21 ECM connector (see my DIY below for that location). If there is 12 V on that pin with the ignition on, then cruise is present.
http://www.yarisworld.com/forums/showthread.php?t=33750
Old 07-23-2013, 10:35 AM   #128
Jadijkstra2000
Drives: Toyota Yaris 2010
Do I need to remove the A21 connector to do the test or leave it in place for testing?
Jadijkstra2000 is offline   Reply With Quote
Old 07-23-2013, 01:58 PM   #129
Leave it in place. You will need to pull the rubber plug if there is not a wire present, so you can stick a piece of wire in to take the measurement.
Old 07-25-2013, 07:09 AM   #130
isidoro
Drives: HDS
Originally Posted by isidoro View Post
Hello CTScott
I write from another part of the world “italy”
I are desperate
I know that we are talking only of yaris
but you are the experts on Cruise Control that I found
I own a hybrid Auris HSD 1,8L
I put all the parts needed as the model with the standard Cruise Control
when I press the button on/off, the lights Cruise Control lights up green
but just release the brake I get a yellow triangle and the following “check Cruise Control “
do you have any advice for me???
thanks so much in advance
foto http://tinyurl.com/nfsms5n
Hi CTScott
problem solved
found missing wire
between ECU and brake switch
Bye isidoro
isidoro is offline   Reply With Quote
Old 07-28-2013, 12:50 PM   #131
Mommas Yaris
Drives: 2012
Just wondering if you have any of these left and if you do how much? If you do would you please comtact me though my email @ cgoretx@gmail.com
Mommas Yaris is offline   Reply With Quote
Old 07-28-2013, 08:35 PM   #132
email sent.
Old 08-20-2013, 12:20 AM   #133
xboxer
Drives: 2007 Yaris Liftback Auto
Same question as above, including the OEM Stalk CC Pin Kit, and Cruise Control Indicator Module. Please send PM. Thanks
xboxer is offline   Reply With Quote
Old 08-20-2013, 06:26 AM   #134
PM sent
Old 03-18-2014, 12:08 AM   #135
Tylard
Drives: 07 Yaris
Interested in purchasing
Do you still have any these?
07 sedan m/t. Cost as well. Thanks
Tylard is offline   Reply With Quote
Old 03-18-2014, 06:20 AM   #136
Yes. PM sent.
Old 03-18-2014, 12:04 PM   #137
nortonfb
Drives: 2007
Please send me the pricing & payment info also.
I have a 2007 hatch. Does your kit include everything necessary?
Thanks
Nortonfb
68 Norton fastback
(Steve)
nortonfb is offline   Reply With Quote
Old 03-18-2014, 01:29 PM   #138
Thanks
Nortonfb
68 Norton fastback
(Steve)
PM Sent. The kit includes everything necessary, other than the tools to do the install.
Old 03-21-2014, 09:52 AM   #139
z0mb13k1ll
z0mb13k1ll's Avatar
Drives: '15 Dodge Challenger
ive got a 2007 sedan, can you pm me with the price and what i would have to do to install? thanks
z0mb13k1ll is offline   Reply With Quote
Old 03-21-2014, 10:34 AM   #140
PM sent
Old 03-22-2014, 07:11 PM   #141
Tylard
Drives: 07 Yaris
Super fast shipping, install not too bad, fishing the wires was def the hardest part. But I cant seem to get it to function on my 07 m/t sedan. I have tried rechecking all the connections and triple check the clutch switch to ensure it is fully pressed in when the my foot is off the clutch pedal.
Any suggestions of what to check?
My wire coming out of pin 40 on the ECM is hooked up and ran through the firewall. I connected this directly to the wire coming out of the slot 1 of the D3 connector. Is this ok or do I need a different wire? If so what is it where do I get it
Old 03-22-2014, 07:17 PM   #142
Double check your pin 1 and pin 2 locations per my DIY (http://www.yarisworld.com/forums/showthread.php?t=33750)
Also, with the ignition switch in the ON position, you can measure the voltage on the pin1 wire and will see 12V if it is connected properly. (Pin 1 is the one that goes to pin 40 on the ECM connector).
Also, double check your pin 40 to make sure you didn't install it on the opposite side of where it belongs.
Old 03-22-2014, 09:02 PM   #143
Tylard
Drives: 07 Yaris
Checked pin 1 and 2 and Im happy with them. Rechecked pin 40 also happy with that.
Checked the voltage. I put my red lead on the connection between the pin 1 wire and the pin 40 ecm wire. Then I put my black lead on the bolt where pin 2 from the d3 connection is mounted. I get 12 v with the ignition turned on. Holding and toggling the cruise on/off switch does NOT make change and still reads 12 volts.
Where the pin 2 wire is mounted there is a black lead already connected to that, I just added on the pin 2 wire and put the bolt back on.
Old 03-22-2014, 09:49 PM   #144
Ah, the pin 2 wire is the "other side". It is the ground for the system.
The black wire is not pin two. It is in the opposite row from pin 2. In this picture you can see the blue wire in pin 1 and the brown in pin 2:
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 467 10-18-2022 10:20 AM
Can we do this? (aka The DIY Cruise Control Thread) mrbond DIY / Maintenance / Service 502 07-22-2017 02:57 PM
This is pretty frikken stupid - Yaris '07 LB auto cruise control firemachine69 DIY / Maintenance / Service 10 07-20-2010 08:09 AM
