Old 03-31-2014, 08:19 PM   #1
Hershey
Thanks CT . I have removed it before to check it and it seemed fine. Looks like I will have to give it the shake test again. Yes it can be difficult to remove. Probably best to do this when the engine is cold. Can you put duck tape over the hole while the engine is running to keep oil from coming out to give it the suction test?
Old 03-31-2014, 08:25 PM   #2
Just try the suck/blow test. With modern cars it is far easier and less messy. I just pull the hose off of the EGR, stick a piece of clean hose (I have a 3' piece of fuel hose that I use) onto it, blow into the hose and the suck on the hose. You should not be able to blow, but when you suck it should resist a bit and then the ball moves and you can continue to suck.
Oil Pan Drain Valve guy2can DIY / Maintenance / Service 16 01-06-2018 05:06 PM
valve noise.... dindy DIY / Maintenance / Service 8 03-13-2013 10:23 AM
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
Paying for the Yaris with a check? YotaYarisUSA New YARIS Purchase Forum 15 07-11-2007 03:31 PM
2007 Yaris LB - Valve Adjustments Pavel Olavich DIY / Maintenance / Service 3 03-30-2007 05:34 PM
