Old 02-13-2013, 02:33 PM   #1
dindy
metallic green vitos
Drives: 2002 toyota vitz. 1.0 auto
Send a message via MSN to dindy
valve noise....
hello there. i got 1.0 automatic 16 valve vitz 4 cylinder. im expercience noise....that i think that is from the tappets or valves... heres my story...when my engine is cold, no valve noise at all!! but when the engine is warmed up, it begins to go tik tik tik tik....at idle, but smooth on driving. i know that it will be an expensive cost to replace the valves .....all i need to ask is, can i use any oil that reduce this tapping noise pls?
dindy is offline   Reply With Quote
Old 02-13-2013, 02:34 PM   #2
dindy
just to mention, the noise is similar to diesel engines...i really hate that noise.
Old 02-14-2013, 04:15 PM   #3
Kens
RS
Kens's Avatar
Drives: Toyota vitz rs 2006
Are you sure it's not an idle issue? Mine starts doing it when it falls below 500 rpm for about 2 seconds but then it automatically revs back up. When it's cold, everything is fine. My mechanic said it's normal.
Kens is offline   Reply With Quote
Old 02-19-2013, 04:02 PM   #4
dindy
heh, i had an idle issue last summer, got 6 months of hell trying to find out, at last i found it was the idle air control valve....270 euros. not funny. no idle now is good. 750 idle to 650.....normal temp. but tickin noise starts after when normal temp is on. on cold strat never.
Old 02-19-2013, 05:23 PM   #5
bairjo
How many miles are on this ticking car?
Old 02-20-2013, 03:52 PM   #6
dindy
dondt know exactly, i will check and repost. i had this car for 5 years now, and i was from the begining that ticking...
Old 02-20-2013, 06:58 PM   #7
mr_miles
Drives: 2013 Yaris
I think you might just be hearing the regular valve noise. we have hydraulic valves so they tend to make noise no matter what. you dont hear it on cold start up because its rpm's are up just enough so it cant be heard.
Old 02-21-2013, 01:00 PM   #8
brg88tx
Drives: 07 Yaris Sedan, Auto
so is this the rattling sound i occasionally hear when just after it shifts and the rpms are low?
brg88tx is offline   Reply With Quote
Old 03-13-2013, 10:23 AM   #9
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
A mechanic needs to check it, if you swallow a valve it's a pretty bad thing. The noise could be perfectly normal, but someone with experience needs to evaluate it.
Amdkt7 is offline   Reply With Quote
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
Help With Reverse Noise???? JoshW DIY / Maintenance / Service 0 09-09-2011 12:27 PM
Valve train Noise hatchbackkid82 DIY / Maintenance / Service 6 12-28-2010 02:27 PM
excessive valve and or engine noise? thomasward00 General Yaris / Vitz Discussion 3 06-07-2007 12:34 PM
