hmm, I haven't inspected mine yet but if this is the case then I'll have to compare the pricing of the strut+mount+coil vs the quick strut. It'll likely just make sense to spend the extra and purchase a quick strut.
My plan for the crash bolt nuts is to spray them with PB Blaster every day for a week leading to actually removing them. Then use an air gun. I;m hoping they will budge loose before any stripping happens. What's the easiest way to remove a stripped bolt if this ends up happening? |
#2 | |
2ZR swap. DO IT! Ask how!
If you have a replacement end link, you can just drill out the stud and be done with it. |
| Strut replacement | jemmah | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 10-07-2011 09:25 PM |
| Front strut replacement/ suggestions | jstantherprsn | DIY / Maintenance / Service | 4 | 04-28-2011 03:39 AM |
| MacPherson Strut Spring Compressor | RacerFreakXXX | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 07-31-2009 08:11 PM |
| Hyperco 5.5" single pigtail rear spring test | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 06-15-2009 10:11 AM |
| DIY spring install says replace strut screws? | counterfiend | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 03-22-2009 07:23 AM |
