Old 03-10-2015, 10:01 AM   #7
tmontague
tmontague's Avatar
hmm, I haven't inspected mine yet but if this is the case then I'll have to compare the pricing of the strut+mount+coil vs the quick strut. It'll likely just make sense to spend the extra and purchase a quick strut.
My plan for the crash bolt nuts is to spray them with PB Blaster every day for a week leading to actually removing them. Then use an air gun. I;m hoping they will budge loose before any stripping happens. What's the easiest way to remove a stripped bolt if this ends up happening?
Strut replacement jemmah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 10-07-2011 09:25 PM
Front strut replacement/ suggestions jstantherprsn DIY / Maintenance / Service 4 04-28-2011 03:39 AM
MacPherson Strut Spring Compressor RacerFreakXXX Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 07-31-2009 08:11 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
DIY spring install says replace strut screws? counterfiend Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 03-22-2009 07:23 AM
