![]() Drives: Yaris 07, Delorean 82 Join Date: Aug 2015
Fusible link wiring diagram
Not sure if new thread was needed or not for this. However my red electrical tape method of marking which wire was which failed me. I had to cut the wires to replace the Fusible link and now am having trouble determining which one is which. I am having trouble finding the wiring diagram for this. Any help? Thanks
One of your wires (curved one) appears longer than the other. I suspect this is the one that goes to the battery clamp side of the fusible link. Don't have access to my car right now to do my own visual.
![]() ![]() ![]() Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR Join Date: Mar 2007
One goes to the starter, the other goes to the alt. I would get a test light and probe each end and see which is which. I will have to do some digging to see what mine was. I know I just used a multi-fuse block when I did my battery relocation.
Edit: After looking at some diagrams, I believe the Alternator cable gets the fuse, and the starter cable goes straight to the 12v+ terminal. I know the littler white wire also got fused.
Project so far: 2zrfe swap, Megan racing coilovers, TRD rear sway bar, whiteline bushings, RPM long tube header, midpipe, and DC sports xD exhaust, brake upgrade in front, MI stainless braided lines all around, matte paintjob, Takada cold air intake, various gauges, rear seat and belts removed. Future: Turbo. |
#4 | |
So how can I determine which one is the alternator even with a multimeter. Both the ones with the plastic connectors are still intact, I was able to get those out easy.
Put the meter in resistance mode and check for continuity (<2 ohms) between each wire and the lug on the alternator. The one to the alternator goes to the rear terminal.
OK, Thanks. Once I started putting everything back in everything fell into place very easily. End result pictured. Thanks for everyone's help.
| Tags |
| fusible link, positive battery terminal |
| Fusible link and Terminal End Removal | smb24601 | DIY / Maintenance / Service | 8 | 08-11-2016 03:16 PM |
| Wiring Diagram for under bonnet (hood?) fusebox | azeeroth | DIY / Maintenance / Service | 5 | 11-11-2013 08:22 PM |
| MK1 Yaris SR - Wiring diagram. | YarisSR | General Yaris / Vitz Discussion | 2 | 08-03-2011 03:44 PM |
| Wiring diagram? | fwynn | DIY / Maintenance / Service | 4 | 05-05-2010 09:00 PM |
| NEED TPMS Wiring Diagram please | mikenacarato | DIY / Maintenance / Service | 9 | 02-11-2009 11:55 PM |
