Still a problem with 3rd gen cars
This is still an issue with 3rd gen cars. Below is a pic of the passenger side LCA bolt from my 2014 SE. I changed them out a week ago because the front end was making a clunking noise and I suspected that the LCA bolts were the issue. They were. No more clunking now. You can read about my adventure here:
http://www.yarisworld.com/forums/showthread.php?t=57576 For those who suspect this may be an issue with their car: The only symptom I had was the clunking noise. The car rode, handled, steered, braked fine. Everything that you could see of the front suspension looked fine too. That's the problem, the LCA bolts are hidden. If you are in a heavy salt area and you are clunking you need to check the LCA bolts. I was able to R&R the bolts with the car on the ground without a problem. As others here have suggested I coated the new bolts with a high quality calcium sulfonate marine grade grease before installing them. Should help for the future, but I'll be inspecting them every year going forward. Toyota needs to update the TSB to include ALL model years and they need to extend the warranty on this to 3rd gen cars as well. P.S. This thread needs to be made a sticky. |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| Cruise control install 2009 Yaris 3 door | PeteZNY | DIY / Maintenance / Service | 125 | 03-31-2024 09:22 AM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
