Old 12-09-2017, 08:14 PM   #1
tmontague
tmontague's Avatar
How was the broken bolt extracted?
Old 12-09-2017, 11:20 PM   #2
yaris2011-07
Drives: 2008 yaris hb ce
Yup, looks bad. I needed to drop the subframe and then heat up the bolt bolt with a propane torch. Once heated, I used a good pair of vise grips and was able to remove the bolt.
The most difficult part of this procedure was getting the control arm bushing to release the bolt since the bolt was rusted solid to the bushing sleeve.
yaris2011-07 is offline   Reply With Quote
Old 12-10-2017, 07:21 PM   #3
tmontague
tmontague's Avatar
I had the same issues on my '05 vibe when I replaced the control arms, took an extra 6hrs and I ended up having to burn out the bushing and enlarge the subframe hole to fit the metal insert through. It was seized so bad I never got it unstuck. An impact was useless as the bushing dampened the impacts.
Now on any car I own I pull the control arm bolts and antiseize the whole thing so it never seized to the bushing sleeve. Takes some time but saves hours down the road
Old 12-10-2017, 09:01 PM   #4
yaris2011-07
I also ended up burning part of the bushing while lowering the subframe.
I torched the bushing sleeve a number of times, so the heating and cooling process along with alot of hammering on the bushing sleeve helped to release it from the bolt.
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
