Help! Cruise Not Working After Spiral Cable Install (FIXED)
I took the '06 in for 5 recalls today. When I got it out on the highway I noticed my cruise no longer worked. I took it back to Toyota and naturally they said they did nothing to it other than unplugging and replugging the cable. I got it home and removed the steering wheel cover and all my wiring looks intact. I reseated the plugs. I have 12 volts at the red wire that comes out of the spiral cable to the cc stalk. My wiring lower in the steering column looks fine as well as my ground. The wire going to the ECU connector in the engine bay is also there. I see two possible options but would appreciate suggestions:
1) the stalk broke 2) the 'new' spiral cable is in some way incompatible with the cc system. The dealer gave me the song and dance and wanted to charge me for 'diagnosing' the problem. I said basically, I used the cc to get here and after you worked on it, it doesn't work. Any help would be really appreciated. Thanks in advance.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 08-01-2018 at 04:59 PM. |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Broken Auto Transmission cable fix | tmontague | DIY / Maintenance / Service | 0 | 09-19-2016 10:16 AM |
| Rostra Cruise Control install done on MT | AlexK | DIY / Maintenance / Service | 34 | 09-18-2007 03:21 PM |
| How difficult is it to install the aftermarket cruise control kit? | grampi | Performance Modifications | 3 | 07-19-2007 08:06 AM |
| official: cruise control install pdf | punch | DIY / Maintenance / Service | 3 | 12-19-2006 06:26 PM |
