Old 07-21-2018, 11:04 PM   #12
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Adam,
You only need to test between the two pine
S in the plug. Ignore the horn wire for this test.
All the switch functions on the stalk are momentary. If the stalk is in its rest postion, you should not see any connection between the pins. You should see a short circuit while pressing the On/Off button, and the other values I mentioned before when operating the stalk to one of the Set/Resume/Cancel positions.
If you can find connector C3 in the steering column, it should have only 2 wires in it, blue and brown. With the ignition swithed on, shorting these 2 wires should turn on or off the cruise control indicator light in the instrument cluster.
Hope you get it working soon. I would be lost without my cruise control.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Broken Auto Transmission cable fix tmontague DIY / Maintenance / Service 0 09-19-2016 10:16 AM
Rostra Cruise Control install done on MT AlexK DIY / Maintenance / Service 34 09-18-2007 03:21 PM
How difficult is it to install the aftermarket cruise control kit? grampi Performance Modifications 3 07-19-2007 08:06 AM
official: cruise control install pdf punch DIY / Maintenance / Service 3 12-19-2006 06:26 PM
