Mind of Toyota clips claws wiring harness connectors
go over the dealers heads and call the 800 phone number in the back of the owner's manual
(yes, what told may be all true, but Toyota wiring harness connecters are all different from each other, the two halves fit very tight, and how to release the tiny and often recessed locking claw is a complete mystery...not in the factory manual. so invites mechanics to get pissed and pry/yank to get the connectors apart. which, duh, isn't good for them.) Last edited by dogsridewith; 07-20-2018 at 07:22 AM. |
#2 | |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Broken Auto Transmission cable fix | tmontague | DIY / Maintenance / Service | 0 | 09-19-2016 10:16 AM |
| Rostra Cruise Control install done on MT | AlexK | DIY / Maintenance / Service | 34 | 09-18-2007 03:21 PM |
| How difficult is it to install the aftermarket cruise control kit? | grampi | Performance Modifications | 3 | 07-19-2007 08:06 AM |
| official: cruise control install pdf | punch | DIY / Maintenance / Service | 3 | 12-19-2006 06:26 PM |
