Old 07-23-2018, 03:50 AM   #15
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
If it's a manual transmission, you might also want to check the switch on the clutch pedal. This should be closed (zero resistance across the contacts) when the pedal is released. If this switch is open circuit, or the wiring is disconnected, the cruise control will not engage.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Broken Auto Transmission cable fix tmontague DIY / Maintenance / Service 0 09-19-2016 10:16 AM
Rostra Cruise Control install done on MT AlexK DIY / Maintenance / Service 34 09-18-2007 03:21 PM
How difficult is it to install the aftermarket cruise control kit? grampi Performance Modifications 3 07-19-2007 08:06 AM
official: cruise control install pdf punch DIY / Maintenance / Service 3 12-19-2006 06:26 PM
