feed my pet
I did enquire with a mechanic regarding rear disc conversion and he briefed me with 2 options.
First option was to swap the entire rear axle complete with disc. Costs with labor would set me back $425. ![]() Second option requires minor modification to my rear axle. He mentioned that there was no mounting holes for the rear calipers. This is where drum/disc axle differs. He needs to mount a fabricated metal plate/bracket for the calipers. He also needs to cut off the back part in order to install this plate/bracket. Photo 28-07-2018, 03 14 15.jpg the metal plates/brackets beside calipers Also he mentioned that the hand brake cable for disc/drum are different so you need to swap that too. |
| Tags |
| disc, disc conversion, drum |
| Possible DIY rear disc conversion | brushforhire | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 25 | 01-22-2024 03:36 PM |
| Need rear brake help! Star wheel/spring combo won't reattach | msapocalypse | DIY / Maintenance / Service | 0 | 10-08-2016 06:19 PM |
| Yaris Rear Driving Lights Problem | ap222 | DIY / Maintenance / Service | 3 | 05-31-2013 05:49 PM |
| drum brake conversion to disc brake | bogartvitz | Performance Modifications | 8 | 04-15-2013 10:21 PM |
