![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
yea i agree it will have a tendency to increase understeer, but again its probably just my setup, i have the cusco rs lsd and am running 205/45/16 slicks on the front so i guess if i were to still have dot tires and stock open differential i can see how it would increase understeer, one thing ice learned with racing fwd is you cannot force the front tires to do more than 1 thing, thats acceleration, braking and cornering all done on the front, tou start accelerating while cornering you will end up “pushing” out of the corner and vise versa, so i guess with dot tires and stock diff yes the front seay bar might do more harm than good, first install a limited slip, BIG tires up front, and .2 toe out alignment and you will see a benefit with cusco front sway bar
#2 | |
The car may feel better on entry with a big bar, more stable, but testing back to back with data will show lower apex speed and delayed acceleration - even with an LSD. Our first car had the Kazz LSD and we would still get inside tire spin with the sedan bar. A big front bar also starts to take away braking force if you are trying to trail brake, as the weight transfers and starts picking up that inside tire. Typically big bars are a bandaid for inadequate springs and shocks.
#3 | |
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
Sorry if this off topic, but has anyone else done this? I felt like it reduced my under steer, but I think it hits my muffler, not sure about the gas tank. I’ll see if I can stick a GoPro under there and go for a drive to find out.
#5 | |
![]() Drives: 2012 Sedan Join Date: Nov 2018
https://www.yarisworld.com/forums/sh...ad.php?t=23911 You are lucky, some of our cars don't have that nut inside the frame to accept the bolt. I am considering drilling a hole in the back side to place one there. |
| 3rd gen front sway bar | m.flores.0928 | Third Gen Yaris General Discussion | 8 | 05-17-2017 11:09 AM |
| xA or xD front sway bar fit in to 07 Yaris | yariseggvvti | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 10-29-2012 09:47 PM |
| My Ultra Racing rear sway bar install | CtrlAltDefeat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 49 | 03-03-2011 02:08 AM |
| C-One Front Sway and 4 Point H-Brace ... SoCal | DuckinOut | Items for Sale by private party | 3 | 09-13-2010 04:38 PM |
| C-One Front Sway Bar | Jerkratt | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 23 | 06-29-2007 10:33 PM |
