Old 01-25-2021, 11:46 AM   #1
Jason@SportsCar
Originally Posted by remcafee View Post
yea i agree it will have a tendency to increase understeer, but again its probably just my setup, i have the cusco rs lsd and am running 205/45/16 slicks on the front so i guess if i were to still have dot tires and stock open differential i can see how it would increase understeer, one thing ice learned with racing fwd is you cannot force the front tires to do more than 1 thing, thats acceleration, braking and cornering all done on the front, tou start accelerating while cornering you will end up “pushing” out of the corner and vise versa, so i guess with dot tires and stock diff yes the front seay bar might do more harm than good, first install a limited slip, BIG tires up front, and .2 toe out alignment and you will see a benefit with cusco front sway bar
I have the OS Giken Super Lock Lsd and Hoosier slicks (not R compounds, full slicks), and no way would I run a bigger front bar. A bigger bar turns compression on the outside tire into lift on the inside, it's physics, and that is the last thing you want with FWD. Whatever you are gaining on corner entry with that big front bar you are more than giving up from the center-off the turn.
The car may feel better on entry with a big bar, more stable, but testing back to back with data will show lower apex speed and delayed acceleration - even with an LSD. Our first car had the Kazz LSD and we would still get inside tire spin with the sedan bar. A big front bar also starts to take away braking force if you are trying to trail brake, as the weight transfers and starts picking up that inside tire.
Typically big bars are a bandaid for inadequate springs and shocks.
Old 01-25-2021, 04:21 PM   #2
remcafee
Hmmm i see i see well that is a good point as i have pretty soft springs in the tein s techs and bilstein shocks thry really arent that stiff, i guess if i had coil overs with better springs i would not do big front bar, i do like the ride quality of the tein spring and bilstein shock combo as this is my daily driver, i try to keep it as a true street car, but once i do coil overs i might end up pulling the cusco bar off, who knows!
Old 01-28-2021, 01:06 AM   #3
Neinris
Sorry if this off topic, but has anyone else done this? I felt like it reduced my under steer, but I think it hits my muffler, not sure about the gas tank. I’ll see if I can stick a GoPro under there and go for a drive to find out.
File Type: jpeg 9B886F3C-FE7F-456B-A5CE-6F6663794680.jpeg (245.4 KB, 147 views)
Old 01-30-2021, 01:45 AM   #4
ElMagnifico
Drives: 2012 Sedan
Yes. there is a whole thread dedicated to it.
https://www.yarisworld.com/forums/sh...ad.php?t=23911
You are lucky, some of our cars don't have that nut inside the frame to accept the bolt. I am considering drilling a hole in the back side to place one there.
ElMagnifico is offline   Reply With Quote
3rd gen front sway bar m.flores.0928 Third Gen Yaris General Discussion 8 05-17-2017 12:09 PM
xA or xD front sway bar fit in to 07 Yaris yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 10-29-2012 10:47 PM
My Ultra Racing rear sway bar install CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 49 03-03-2011 03:08 AM
C-One Front Sway and 4 Point H-Brace ... SoCal DuckinOut Items for Sale by private party 3 09-13-2010 05:38 PM
C-One Front Sway Bar Jerkratt Wheels, Tires and Suspension Forum sponsored by The Tire Rack 23 06-29-2007 11:33 PM
