Old 07-02-2007, 05:41 AM   #3
ChinoCharles
Drives: LB
Originally Posted by YarisGuy View Post
There are a few things to keep in mind when dyno testing.
1. Before and after dynos should be done on the same day to keep the weather and humidity in check. Doing a dyno today and then going back in a couple weeks will change these conditions and can lead to inacurrate readings.
2. How does your area under the curve look? You should plot the before and after lines on the same page to look at the area under the curve. Peak numbers are over rated and don't mean as much as the behavior of the power and torque curve.
3. Did you use the same dyno? Was this dyno recalibrated or were the settings changed in any way during the two weeks that you were away? These can also change the readings.
4. etc. etc. etc.
Almost all dynos will automatically correct results based on weather conditions to ensure that results are accurate despite being taken on different days. You are right, though... the area under the curve will tell you if you have a faster car or not.
Dyno test of my Yaris TS 2001 PowerDyn Performance Modifications 9 05-07-2007 10:26 AM
anybody have dyno charts for superchargers turboyaris Forced Induction Forum 4 04-09-2007 03:37 PM
WR Yaris Intake Picture & Dyno. WRLEO Performance Modifications 37 04-05-2007 07:02 PM
dyno results are in!!!! turboyaris Performance Modifications 105 04-01-2007 06:03 PM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 10:14 AM
