Old 09-26-2007, 01:57 AM   #11
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Originally Posted by 03Z33 View Post
I'm trying to upload the picture from the repair manual right now.
You must have the strut bearing and the nut tightened onto the strut before installing the upper rubber portion and before installing the strut into the car. There needs to be some preload on the spring (or at least the ability to preload it).
From the picture it looks like the stock strut bearing may press right into the red anodized spring seat? If so, then you should be able to tighten the nut up to the bearing before installing into the car.
I had originally used the entire seat from the OEM strut. Is this not correct? How do I get just the bearing off? That'd make some sense. Currently, this is what the assembly looks like (gotta love MS paint and that fact that I haven't taken any photos of the actual setup yet):
Megan Springs? churp Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 06-06-2007 03:11 PM
Megan or Tein suspension elmercurrie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 43 05-31-2007 09:41 PM
Comp S Coilovers for a discount and installed BulletProofAuto California 1 05-12-2007 01:04 AM
cusco coilovers installed badhabitz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 02-03-2007 04:43 PM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 07:45 AM
