Old 12-16-2008, 11:08 AM   #15
Rich k
Rich k's Avatar
Drives: 07 3dr white Yaris 5spd stock
Send a message via AIM to Rich k
P.S. most cars with an auto trans lockout the highest gear and hold the lower gears longer when the engine is cold, like another member said, its to heat the engine up quicker by forcing it to work under a greater load untill it is warm. Every car that i've owned with a fuel injector system has been like this. Its not a safety concern, the car will go just as fast as it would with the top gear its just going to rev a lot higher to get there and may seem like it doesn't want to, though thats simply the car and the mfr telling you not to really push it with a cold engine. Buying any other car on the market in the US with an Auto trans will get you the same feature you complain about on the Yaris, do your homework before you put yourself thru a lot of wasted time and money getting a new car just because of this.
Rich k is offline   Reply With Quote
HELP WITH NEW 2007 PROBLEMS partenac General Yaris / Vitz Discussion 15 05-31-2007 06:06 PM
some minor problems after installing my HID kit, any professionals? ASHRAF DIY / Maintenance / Service 14 03-09-2007 11:54 AM
headlight problems KSIbucky DIY / Maintenance / Service 2 02-28-2007 11:54 PM
Timing chain, sprockets, & cam position sensor problems? PetersRedYaris DIY / Maintenance / Service 8 01-04-2007 12:50 PM
major problems? kaymm General Yaris / Vitz Discussion 3 09-18-2006 09:25 AM
