#19 |
help! my Yaris shrunk!
Drives: 12 Hot Lava iQ/07 Jade Vios Join Date: Jun 2007
#20 |
P.S. most cars with an auto trans lockout the highest gear and hold the lower gears longer when the engine is cold, like another member said, its to heat the engine up quicker by forcing it to work under a greater load untill it is warm. Every car that i've owned with a fuel injector system has been like this. Its not a safety concern, the car will go just as fast as it would with the top gear its just going to rev a lot higher to get there and may seem like it doesn't want to, though thats simply the car and the mfr telling you not to really push it with a cold engine. Buying any other car on the market in the US with an Auto trans will get you the same feature you complain about on the Yaris, do your homework before you put yourself thru a lot of wasted time and money getting a new car just because of this.
#21 | |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
I don't have that problem because mines not auto, but I'm sure the feature is to protect your transmission under cold conditions...sort of like certain vehicles that protect compressors when they won't switch on when it's too cold out, or certain HP cars that won't make boost if the engine is too cold... |
#22 |
WFO
Drives: 2008 hb Join Date: Oct 2008
#23 | |
![]() ![]() Drives: 08 Polar white hatch Join Date: Oct 2008
TELL ME WHERE TOYOTA SAYS ANYTHING ABOUT IT! |
#24 |
![]() Drives: 08 Flint Mica Sedan Join Date: Dec 2008
I can't see toyota featuring this function in TV ad anytime soon. What is the RPM at 40 mph and 3rd gear?
Recent cars I've owned with this "feature" Hyundai Elantra automatic 4 speed, Suzuki Aerio, automatic 4 speed, Kia Rondo, automatic 4 speed. All of these had more powerful engines so getting out of the way wasn't an issue. The Aerio was the most annoying, others it was barely noticeable. I test drove the automatic trans Yaris and decided it may not be a good idea. That was not even considering the lockout feature when it was cold outside. Solutions? Park in a heated garage Swap for a manual transmission Yaris I would think all comparable cars of this size with automatic transmissions would have the same lock out and be really annoying with a small engine. |
#25 |
I don't know because it does not have a tach. I really like this car but this is really annoying. I guess its an econo car thing and I will have to live with it. It is a safety issue tho. |
#26 | |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
then you kept on driving? What did you check to give you the confidence that you wouldnt lose your brakes again?
#27 | |
![]() ![]() ![]() Drives: 08 LB BLACK Join Date: Oct 2008
Your in New Jersey and here in SE NY the winter has not really began yet. I have an automatic and have not noticed the shifting problem on cool mornings. What are you going to do when it gets really cold? Of course, I wait until the car is warmed up a few minutes so maybe that is why I have no problem. But 0 temps will be here in January / Feb so maybe you have to let your car warm up or else you have another problem? |
#28 |
#29 |
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
You can have mine(j/k). I think they are pointless....even on a standard.
#30 |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
WELL ORIGINAL POSTER (O.P) any update?
#31 |
![]() ![]() Drives: '08 Liftback and Mountain Bike Join Date: Oct 2008
I like the "warmup" mode the car enters upon starting and being cold. Keeps me from going to fast in the school one right by my apartment on the way to work.
Although I am sure all the moms in their SUV's who think they need to drive 60mph in a 25mph zone sure don't like to be behind me in the morning!
#32 |
My Little Blue Egg :)
Drives: '09 3 door Yaris Join Date: Dec 2008
Okay, so i took the car back to toyota, and they checked it all and ran it thru computers and such..and they came back with nothing. They claim they did nothing on my vehicle, but the brakes are 100% better now. So the brake problem is better. I have not had the problem yet, so im keeping my fingers crossed. About the acceleration issue, they said it was fine, and so far it has not done it again. Ive began letting my yaris warm up in the mornings to prevent it from happening again. (if it was due to it being cold out) I love the car, but if the problems happen again i duno what im gona do. I dont know what i can do. So just cross your fingers that its fine! :D
#33 | |
#34 |
OMGWTFKITTYKATMEWMEWMEW
Drives: 2008 Yaris S Join Date: Oct 2008
it takes like two blocks or maybe a minute or two for my car's cool temp light to go off, does anyone really live that close to a freeway that they need to be doing 40+ mph almost immediately after starting up the car? If you're driving on the freeway while any car's engine is still warming up, I think you've got more issues to worry about than just safety.
#35 | |
MORDSITH
Drives: 2007 Yaris Hatchback Join Date: Apr 2006
2007 Yaris Hatchback 5 Door LE, Manual, Package B, Bayou Blue Metallic |
#36 |
Gamer Chick
That's what that light's about. I asked about it at the dealership and they didn't give any real reason, just "Your car is ok". Good to know!
| HELP WITH NEW 2007 PROBLEMS | partenac | General Yaris / Vitz Discussion | 15 | 05-31-2007 06:06 PM |
| some minor problems after installing my HID kit, any professionals? | ASHRAF | DIY / Maintenance / Service | 14 | 03-09-2007 11:54 AM |
| headlight problems | KSIbucky | DIY / Maintenance / Service | 2 | 02-28-2007 11:54 PM |
| Timing chain, sprockets, & cam position sensor problems? | PetersRedYaris | DIY / Maintenance / Service | 8 | 01-04-2007 12:50 PM |
| major problems? | kaymm | General Yaris / Vitz Discussion | 3 | 09-18-2006 09:25 AM |
