Old 02-09-2009, 10:23 AM   #11
turboyaris
Drives: 2007 Yaris Sedan
Send a message via AIM to turboyaris
its not attached to plastic, it uses the same mounting points as the factory seat belt system. the mounting tab is 3/16" chromoly, I'm not sure how much more substantial you would want it. I won't include any foam to put on the bar... it's not something you can have installed while having passengers in your rear seat, foam or not. You can install it with or without the factory seat belts in place, if you have passengers in your car occasionally, it can be removed with 4 bolts, leaving the brackets in place.
It probably does little to add rigidity, the main purpose is aside from a roll cage, there is no way to attach 4pt harnesses in your car.
turboyaris is offline   Reply With Quote
Gauging Interest: Whiteline Front/Back Adjustable Sway Bars RaptorRacing Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 12-15-2009 04:23 AM
F.S. MOMO Acropolis Evo Carbon Kevlar Competition Seat with 4 piont Harness Ric n Sov's Vitz RS Items for Sale by private party 2 10-19-2008 01:34 AM
Yakima Q towers and roof mounts (no bars, locks) for sale $125 shipped pxpaulx Items for Sale by private party 6 04-24-2007 10:54 AM
How exactly does an heavier duty harness work? IsLNdbOi Performance Modifications 5 09-26-2006 04:19 AM
