Old 02-16-2009, 09:40 PM   #19
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
hes right yoda, dont laugh. i used a 3" housing to try and see if a 3" intake would work...it doesnt
Old 02-18-2009, 10:13 PM   #20
BlackMan_Ink
Drives: 07 Yaris, 4dr Daily Driver
I got an AFE intake and I am having the same problems I went over the hoses with a fine tooth comb, and the only thing I can think of is that the plastic elbow is leaking air, I'm pretty sure I put the MAF sensor on tight, even tho I had to get some extra washers to get it to stop wobbling on the housing. I'm going to add sealant to the hose and elbow, hopefully that solves the problem. Any suggestions on where I should be looking?
Live, Life, Lavishly!
BlackMan_Ink is offline   Reply With Quote
Old 02-18-2009, 10:17 PM   #21
YarisSedan
Drives: 08 Yaris Sedan
What CAI intake brand did you use. I never heard of any intake besides one on ebay that would require you to use sealant on it.
Old 02-18-2009, 10:30 PM   #22
BlackMan_Ink
i got an AFE intake, I got it from a reputable parts store in Burbank, it came with all the parts and had all the emblems molded on the parts, it's legit... but for some reason it just didn't fit perfect.
Old 02-18-2009, 10:30 PM   #23
BlackMan_Ink
i got the one you got the AFE stage 2 intake... or at least thas wut the box said... =)
Old 02-18-2009, 10:35 PM   #24
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
bad maf would stall the car and not even run
check the tightness of the filter and tube
Old 02-18-2009, 10:41 PM   #25
LBjoe
LBjoe's Avatar
Drives: Red LB
If there is a leak before to the MAF it can read that amount of air and correct the fuel still could cause a rich condition but i dont believe that would throw a code.. NOW if it's after the MAF you have un metered air reaching the engine causing a lean condition and that will pop a CEL quickly... Thus i'd be contacting AFE asking as to why the MAF housing is not providing a correct fit as well as making sure you have not damaged the fillament on the MAF by rigging it in the intake with washers they are kinda touchy oil from our hands can cause them to trip a light... just my two cents.
TRD
LBjoe is offline   Reply With Quote
Old 02-18-2009, 10:44 PM   #26
mikenacarato
SIPNDEW
Drives: 15 STI
so will an incorrect diameter MAF tube.
Old 02-18-2009, 11:04 PM   #27
BlackMan_Ink
thanx, I'm going to give it another once over and hopefully it won't go off on the ride home.
Old 02-20-2009, 08:31 PM   #28
BlackMan_Ink
Talking problem solved
I am still getting a CEL, but thanx to Garm I now know what the problem is(the bolts that came with the sensor are too long and the MAF is not sitting on the intake properly causing a leak) and will have it fixed A.S.A.P. Thank you again to all, for the help.
Old 02-21-2009, 02:13 AM   #29
Yes - I got one right!
Great to meet you today.
Old 02-21-2009, 11:07 AM   #30
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
yup its the diameter..i ran into this problem.. 3 inch wont work at all..i believe its 2 1/4 inch is the stock... but i ran into someone that had bigger diameter..dont know how he did it..he said it was the distance between the maf and the filter.
Simota Carbon Charger Cold Air Intake lilredrocket Performance Modifications 18 04-13-2009 03:16 AM
guess what I'm waiting for and how much I paid? Ric n Sov's Vitz RS General Yaris / Vitz Discussion 27 06-27-2007 07:36 PM
problem with cold air intake skc Canada 24 06-18-2007 07:34 PM
Cold Air Intake vs. Short Ram Intake nevermorez Performance Modifications 1 01-24-2007 04:25 PM
