Have you adjusted the idle screw? If you've turned the screw out too far you could get this code...try turning the screw in one or two turns (with the car off). This should fix the problem.
If you haven't adjusted the idle set screw, turn it counter-clockwise 1.5 turns (with the engine off), and see what happens. Last edited by jkuchta; 05-21-2009 at 04:11 AM. |
| 1.8L Engine Swap, Possible? | Yaris T-Sport | Performance Modifications | 4 | 05-06-2007 06:57 PM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
