#20 |
![]() ![]() Drives: white stock yris Join Date: May 2009
If you put a washer under each lower bolt wont this also adjust the toe to a little out because the front bolt is higher then the rear?
Would you need more negative camber for track with stock springs and a rear sway bar then stiffer springs all around because the body rolls more? How much camber is too much? |
| Hyperco 5.5" single pigtail rear spring test | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 06-15-2009 10:11 AM |
| Ultra Racing 23mm Rear Stabilizer Bar | Loren | Performance Modifications | 62 | 05-18-2009 07:20 PM |
