Old 06-27-2009, 06:18 PM   #1
Stiv
Drives: Yaris TS 1,8L
Well, the thing is that with a quick inspection of the engine bay, I noticed the airbox was shaking in idle (around 700rpm), but then again, the whole motor is shaking and I can't remember if that was the case before.
On the way home about half an hour ago, I pushed the car a little harder after letting it cool down a bit (let's say 2 hours), and the rattle was there, but I had ti press the pedal a lot harder this time.
And yes, the sound is coming from the left side of the engine bay.
Btw. intake is stock. Actually everything is stock except headunit and subwoofer.
I'll check the bolt that holds the intake in the morning.
Stiv is offline   Reply With Quote
Old 06-27-2009, 07:59 PM   #2
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
yeah, check the bolts, and make absolutely sure that the air filter cover is snapped on securely, it can be a b*tch sometimes to get it on correctly.
Old 06-27-2009, 08:17 PM   #3
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
It could be the heat sheild on your excuast, worth a look any way.
Yaris engine loud..? buccaneer64 New YARIS Purchase Forum 33 01-25-2009 01:45 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 11:53 AM
excessive valve and or engine noise? thomasward00 General Yaris / Vitz Discussion 3 06-07-2007 01:34 PM
Loud scratching noise dngz General Yaris / Vitz Discussion 3 09-11-2006 11:56 PM
engine noise?? poshi General Yaris / Vitz Discussion 23 09-04-2006 11:45 PM
