The one with cheese on it
Drives: '10 Corolla S Join Date: Oct 2008
Okay...I am at a lost.
I received the wire from TRDSparks. I installed the cruise control switch and the clutch switch. Nothing is turning on or engaging. I then jumped the wires in the fuse box to bypass the clutch switch...still nothing. I then took off the airbag again and double-checked the wires, everything is locked in.....still nothing. I even connected the white wire to the purple wire and found out that it starts the car!! I am not getting any "Check Engine" or "Airbag" lights in the cluster, so that's a plus I guess. Could I possibly just have a bad cruise control switch or am I missing something? If y'all have any ideas, I am all ears. ADDED CORRECTION: Umm....I think I just screwed up....I have the '08 LB, so I had to connect a blue wire from the ECM to the connection behind the steering wheel, right?
DIY: A/C Insulation Last edited by texkid; 07-30-2009 at 12:31 AM. Reason: A light bulb just went on over my head... |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 01:37 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 10:12 PM |
