Old 07-31-2009, 02:50 PM   #11
cdydjded
Drives: Yaris LB Turbo
1.What parts of the xa/xb 1NZFE GREDDY turbo kit can be used?
No one really knows 100% the answer to this it has not been tried by anyone here, the xB & Yaris only share the engine, the engine bay is completely different
2.Can E-manage plug and play work with the stock ecu for 7psi?
Greddy does make a PNP for the Emanage Ulimate for the Yaris, it is only sold thru Trust in Japan
3.Can you use any plug and play for the yaris?
See above, Boomslang is working on a PNP harness at this time
4.If plug and play can't be used, I assume AEM standalone is your only option?
No need to go to a standalone at low boost, will it run better yes, many here are running with stock ecu's & have had good results
5.Will anything need to be done to the motor if you are running 7psi?
based on the results of the bo0sted cars so far 7psi wih stock inernals is OK
6.What is the general price of everything needed for 7psi?(directed at you garm, I am assuming you have done the most research, I am looking to spend 4k roughly)
Under 4k no problem
cdydjded is offline   Reply With Quote
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 10:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 12:30 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-26-2007 11:18 PM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 08:45 PM
