What kind of car is that?
Rear camber
are there any DIY's on how to use the EZ shim on our car?
Reluctantly Crouched...
they've probably been pulled and put on that other forum, since sharing DIY's is apparently not as cool as it used to be. IMHO, its probably best to let the alignment guy put them on, since they are the only ones who can measure the results anyway. At NTB, that is part of the cost for alignment, so they're used to installing those when needed. My guy insisted that I let him do it so the wrong tabs didn't get popped out. As much as we expect our suspension to be symmetrical from the factory, it often isnt.
its def not symmetrical
i have a ton of tools here in our garage i would not be surprised if we had the tool to measure it at very least id still like to know what the procedure is
| Adjusting rear camber?? | PHXDEMON | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 63 | 10-23-2009 12:11 PM |
| New Product: Penguin Garage Rear Camber Shims! | Penguin Garage | Penguin Garage | 11 | 10-22-2009 10:20 PM |
| Rear Hub Spacer camber? | SweetRS | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 23 | 08-26-2009 04:10 PM |
| Hyperco 5.5" single pigtail rear spring test | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 06-15-2009 10:11 AM |
