I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
it's very easy to install you might not even need to lift the car to do it... you pretty much only need a wrench. (I think lifting the car would be safer tho)
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell |
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Yeah, me installing it is not going to happen.
![]() I've never worked under the car and don't know where I'd even attach it. I could go to my Toyota dealer and have them install it, but then that would bring the total cost way over what it's worth. |
Everybody starts somewhere and this is a good place to start. It *really* is as easy as everyone says it is. Four bolts and you're done.
#4 | |
It's four bolts! Follow the instructions and take a walk on the wild side. Or bring some lubricant along to the $tealership because they're going to bend you over. ![]() The corner garage might be more $ane.
I ♥ Yaris
pity you are too far from me, I'd do it for $20
If you can change a tire you can install this. OR you must have a friend that can help (two people makes it so much more fun).
If you want to call me on the phone, I will coach you, in person, through the whole thing.
I've never changed a tire before, but if you can coach me over the phone that might work.
#8 | |
![]() Just find the DIYs on here, print them out, and call garm if you get stuck(which you really shouldn't) |
^ what other parts dealer would do that?
None that I know of....
![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
Garm really will help you through it over the phone. I know firsthand because he helped me get the 23mm UR bar on when I thought there is no way it would fit. Thanks again for that help!
I don't have any tools or gear to raise the car and someone said it would be dangerous and difficult to do w/o raising the car.
I ♥ Yaris
you will have to remove the nuts that hold the shocks on both sides... one side you can just slip on over the bolt... the other side you have to pull the bolt out in order to get that side into position, personally I'd be afraid to move the bolt out of the shock with the weight of the car pressing on it. Not to mention how hard it would be to move the bolt... I put my car on jack stands then jacked up the crossbar a tiny bit to loosen the pressure on that bolt, but beyond that, it's 4 bolts you have to deal with...
I was following just fine until you got to the words jack stand. Is that the thing under the driver seat? Won't "jacking" up the car on one small point like that put too much pressure and then warp that small point you jack the car up on?
![]() ![]() Drives: 2006 Mazda3 Sedan Join Date: Jun 2007
If the car is a daily driver, I'd worry more about the suspension setup of a 23mm than I would the price. Assuming the material is similar and that both bars are solid there's a much better chance of inducing snap oversteer withn the stiffer rear bar.
#15 | |
I ♥ Yaris
So you recommend the 19mm one?
I recommend knowing what problem you're trying to fix and what side effects it has before starting to throw parts on your car. That's it.
#18 | |
Drives: Yaris 2DR LB 07, MT, Abs. Red Join Date: Feb 2009
http://www.yarisworld.com/forums/showthread.php?t=14084 It might help you answer the 19" v. 23" question. If you don't have any tools, maybe you could go to a meet and see if some of the members are willing to help you out? |
| DIY - rear sway bar [pics] | cali yaris | DIY / Maintenance / Service | 199 | 07-28-2022 05:25 AM |
| Ultra Racing 23mm Rear Stabilizer Bar | Loren | Performance Modifications | 62 | 05-18-2009 07:20 PM |
| Does the TRD rear sway bar promote tire wear? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 03-29-2009 10:29 AM |
| Rear Sway Bar Instructions - Additional Pics | SeaYa | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 02-26-2009 01:05 PM |
| solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-05-2008 11:37 PM |
