rice rocket
Drives: 05 Echo Join Date: Feb 2007
how about attaching the LED strips to the bottom of the door frame? You will require the SMD LED strips because the clearance is very low. Just clean the bottom frame, double sided tape (I also used clear tape for some extra adherence). You just need to run the wires through the doors which requires removing the door panel to get access.
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| DIY: Yaris LB Halo Led Projector Headlights | goku87 | DIY / Maintenance / Service | 37 | 11-15-2013 06:23 AM |
| Door Handle LED DIY with pics | window_lee | DIY / Maintenance / Service | 93 | 05-31-2012 11:58 PM |
| DIY: LED side mirror installation | eTiMaGo | DIY / Maintenance / Service | 85 | 06-24-2011 11:48 AM |
| DIY for Low Cost Dim Light in the light LED | tang | DIY / Maintenance / Service | 0 | 03-08-2009 10:58 PM |
