Old 01-15-2010, 08:44 AM   #3
If you have access to a multimeter, you can check the powered off current drain yourself. This is from a post I made in another thread a couple of months ago:
On my 09, which has keyless entry and remote start, I measured the off state current draw at approximately 300mA. This means that in 24 hours this powered off Yaris will use 7.2 Amp Hours. This is a significant amount of draw, as it means that this sitting Yaris will have a dead battery in less than two weeks.
On Crashy, who is a bare bones 08, I measured the off state current draw at approximately 160mA, which equates to 3.84 Amp Hours of draw in 24 hours.
In doing some measuring of current draw of various things while the ignition is off I found the following to have the most significant draw while powered off:
ECM: 50mA
Body ECU: 100mA
Radio: 5mA
Clock: 5mA
Keyless Entry/Remote Starter on my 09: 150mA
The ECM, radio, and clock are all reasonable. The keyless entry / remote starter on my 09 is no surprise as it is an active system waiting to hear from an RF remote. The body ECU is the one that really surprises me. This is an ECU that is built into the white plastic chunk that we tend to refer to as the under dash fuse panel.
Auto trans. drain and fill? FochMan DIY / Maintenance / Service 5 01-07-2010 11:41 PM
What electrical polisher do you use? tomato Wash, Wax, Detailing, Exterior Repairs 11 09-01-2009 12:34 PM
Oil drain plug gasket question schleppy DIY / Maintenance / Service 7 04-17-2009 05:35 AM
What trailer electrical connector required? charles nelson DIY / Maintenance / Service 3 01-16-2009 04:51 PM
