Old 02-14-2010, 03:38 PM   #11
Originally Posted by Falconia View Post
Are you sure that my car have DRL. Headlights turn on when starting the engine. Is that the sign of DRL and that can't be done otherwise?
I'm just thinking why Toyota service have never heard about DRL in here.
The headlights turning on when the engine is running is the definition of daytime running lights, so I am almost positive that your car has DRL. There are other ways to achieve the same effect, but not from the factory. You may be able to get at the DRL module (or at least see if you have it) by removing the speedometer trim and speedometer. That may give you enough space and the correct angle to see or feel the module.
