Old 06-17-2011, 10:30 PM   #1
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Drop me an e-mail about the CD. Remind me what I'm doing for you...it's been a while.
..and yes, I'll be doing both surfing and snowboarding! :) I'll report to you how the system works with this much headroom and control. Something tells me it'll be juuuust fine.
D,
You could also look at thread-serts. They're like the ones I used in my A-pillars for the L4 baffle.
Also, take a look at what I have access to:
Something tells me you may want this reference disc? I can burn you a copy...
Yes please!
D.
CLA 250, 4MATIC
Old 06-17-2011, 10:35 PM   #2
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Got it...
I'll trade you a picture for a picture:
That's Aaron, one of the guys at the shop. He's right at 6'2". That gives another idea of how big the amplifiers is.
― Thomas Paine
Old 06-17-2011, 10:43 PM   #3
derickveliz2
Got it...
If we count the tiles it's a little over 3.5 feet or 42 inches.
D.
CLA 250, 4MATIC
Old 06-20-2011, 11:35 PM   #4
sqcomp
Roadrunner Jr.
sqcomp's Avatar
D.
It's exactly 36"...I have 40 inches between the pass through. It's a little tight...and WTH?!? The web site says 24.5" for the S2b. Ooops!
^That board you see the amps on is the same one I had the LRx's on. Something to think about there!
RAWR!!!!
The 320 Ampere DC Power alternator will be hand made and in my paws in 5 weeks.
― Thomas Paine
Old 06-21-2011, 02:52 AM   #5
derickveliz2
Talking
RAWR!!!!
Not fair, I'm going to start signing my post as a Double "D" now...
DD
CLA 250, 4MATIC
Old 06-17-2011, 10:41 PM   #6
derickveliz2
I think you need a roof rack! I'm jealous!
CLA 250, 4MATIC
Old 06-18-2011, 12:30 AM   #7
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I dunno if the two channel is big enough...
― Thomas Paine
Old 06-19-2011, 04:43 AM   #8
derickveliz2
Arrow
I dunno if the Yaris is big enough for all this... LOL
Man matching the angles of the Mids on the A-pillars it's not easy.
D.
CLA 250, 4MATIC
Old 06-19-2011, 06:30 AM   #9
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I haven't actually had my hands on the amps yet. On Monday, I'll be up at the shop to continue work on the L6SE kicks...placing/aiming and glassing the baffles. Hopefully I can get them essentially finished. I have to lay down some more glass today and use some short strand on the inside just to build up the inside and even the surfaces out.
I've taken out the amp board that held the LRx's. I'm conceiving of several ways of placing the amplifiers. I REALLY want to keep the woofer inverted to show off the magnet. I'm considering running the amps in a north/south configuration...parallel with the front of the car...sort of angled as well as to be placed around the woofer, one on each side of it (the two big ones) and one in back of it closer to the seats by the Bit One.
Thinking, planning...
enough about me, what is going on with your mids? I noticed the picture on the last page with the wood baffle...what was that about?
― Thomas Paine
Old 06-19-2011, 09:31 AM   #10
derickveliz2
Arrow
If you are talking about this picture is from another DIYMA member at the Massachusetts meet.
If you are talking about this picture, yes they are out of the spheres going off axis on the a-pillars
D.
CLA 250, 4MATIC
Old 06-20-2011, 02:58 AM   #11
derickveliz2
I was just playing with glass on the Pilots a-pillar and new Mids baffle, this is my first a-pillar build so lets see how it goes! Oops no pictures I don't have my camera with me... I'll take some tomorrow.
D.
CLA 250, 4MATIC
Old 06-21-2011, 02:58 AM   #12
derickveliz2
D.
DD.
CLA 250, 4MATIC
Old 06-21-2011, 09:50 AM   #13
TOLMACH
Drives: soarer
Hi Derick
I am impressed with your committment to get the proper instal in your car.. Couple comments on your last pics with A-pillars podiums:
1. I normally do lots of sanding before applying epoxy or fiberglass resin (sorry, do not know how to call properly the compound you use). Sanding DOES improve adhesion. Sometimes drill lots of tiny holes if in doubts whether the whole shit will hold strongly. Totyota uses sometime crazy plastics for its a-pillars - nothing sticks perfectly.
2. I also prefer to cover the entire a-pillar with fabric I use - one or two layers is normally enough for tweeters based on the material density (thickness).. more layers may be necesary for a midrange pod. Covering the entire pillar helps make the surface smoother, requres less sending, less layers of putty and seems better in a sense that the pods won't separate from the pillar body. See link to pic below: pink stuff is the fabric. This picture under the link is not mine but it helped me do couple pods myself.
http://www.drivesound.ru/installatio..._01_31_800.jpg
Old 06-21-2011, 10:48 PM   #14
derickveliz2
Unhappy
Originally Posted by TOLMACH View Post
Hi Derick
T. you are absolutely right!
After applying good amounts of torque to the pillars some areas give up! what I mean is that I could tell is not a 100% bond.
So I'll drill some holes on top and beyond the fleece, and apply another layer of glass. Then fill in the inside with clay and silicone.
Besides that feels strong and the baffle is rigid and solid.
D.
CLA 250, 4MATIC
Old 06-22-2011, 03:11 AM   #15
TOLMACH
Drives: soarer
D.
tiny holes spaced 5 milimiteters apart around the whole perimeter will save you ))
I am in russia at the moment - I can easily buy here the regular epoxy rather than fast drying fiberglass resin becasue it is way stronger in term of adhesion (though dries very slowly - around 24 hours per layer) - I normally try to use epoxy for such strange plastic parts (sometimes i start thinking it is not pure plastic but some mixture of plastic and rubber)
I do not think silicone will help you in any eay- concentrate on building the proper outer shell of the pod
Again, sorry for being stubborn - think about covering the whole piece (with lots of prior sanding with harsh sandpaper) can be a solution to your "applied torque and crashed" problem
As requested, I wish you best of luck!! ))
Old 06-22-2011, 03:41 AM   #16
derickveliz2
Arrow
Yes, I did punch a bunch of holes and it's drying right now, we'll see tomorrow. Thank you.
I'm using Silicone inside! not outside, I know Glass can get very strong but also too hard it would crack at some point, so the silicone inside around the baffle. (this is just me, who knows if it helps or not)
I'm really thinking about covering everything, but we'll see (I feel lazy now too much work jeje)
So you are in Russia? do you have a picture of your Yaris over there?
Thanks
D.
CLA 250, 4MATIC
Old 06-22-2011, 06:44 AM   #17
TOLMACH
Drives: soarer
Thanks
D.
Sorry, no picture of my yaris because... I have no yaris yet ((
I am moving (relocating) to Vancouver BC next month, hence, being a newcomer, thinking of buying something good on gas. I am not big fan of small cars but somehow I find yaris HB cute. I also think it is a great car for car-audio purposes (nice a-pillars and doors, etc.). I do not yet have any job in Canada hence my yaris project should be progressing pretty fast )) .. I started collecting stuff for this new project already )) Will keep you posted
Old 06-21-2011, 11:27 AM   #18
derickveliz2
Thumbs up
Thanks T.
1. I should have done some sanding you are 100% right on the dime, me bad been lazy or tired I forgot )o:
So far the a-pillars material is pure plastic, nothing like my corolla's a-pillar material, looks like nothing would stick to it, I agree with you.
We'll see how it goes.
2. I also agree with you to cover the entire a-pillar with fabric, now that I think about it, I can think of 2 things... One is I wanted it to keep it light,
the second one, my working table is way too small that I was afraid of doing the entire pillar, I may get screw up finishing but that's the process of learning right?
Wish me luck, and thanks keep them coming.
D.
CLA 250, 4MATIC
