Old 06-22-2011, 03:11 AM   #11
TOLMACH
Drives: soarer
T. you are absolutely right!
After applying good amounts of torque to the pillars some areas give up! what I mean is that I could tell is not a 100% bond.
So I'll drill some holes on top and beyond the fleece, and apply another layer of glass. Then fill in the inside with clay and silicone.
Besides that feels strong and the baffle is rigid and solid.
D.
tiny holes spaced 5 milimiteters apart around the whole perimeter will save you ))
I am in russia at the moment - I can easily buy here the regular epoxy rather than fast drying fiberglass resin becasue it is way stronger in term of adhesion (though dries very slowly - around 24 hours per layer) - I normally try to use epoxy for such strange plastic parts (sometimes i start thinking it is not pure plastic but some mixture of plastic and rubber)
I do not think silicone will help you in any eay- concentrate on building the proper outer shell of the pod
Again, sorry for being stubborn - think about covering the whole piece (with lots of prior sanding with harsh sandpaper) can be a solution to your "applied torque and crashed" problem
As requested, I wish you best of luck!! ))
