Old 03-18-2010, 11:47 AM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
well if 15x8 +0 is absolutely going to be a problem which seems to be the consensus then I guess ill be going with 15x8 +15 and ill still get to poke which is what im going after.
how about 15X9 +36?
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
Old 03-18-2010, 01:30 PM   #2
Split
Drives: 2008 Yaris Sedan
you guys are crazy.. you want to be running the HIGHEST offset possible because that's what this car is set-up for. If you're doing a 15x8, you'll want at least a +40 offset. if you run a high enough offset, you might even be able to get away with running a 225 width tire.. like a 225/45R15. Or if you want that stretched look you can run a 215/50R15. <- that's about as far as you can safely stretch onto a 15x8.
Split is offline   Reply With Quote
Old 03-18-2010, 04:45 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
you're wrong actually..
and i hate stretch.
Old 03-18-2010, 05:28 PM   #4
AdeJong 03
"Stealth Runner"
AdeJong 03's Avatar
Drives: 2009 Yaris-S Sedan
incredible amount of misinformation
also, the op isnt actually asking for what the widest he can run is, he wants to know how aggressively he can make his wheels fit.
Old 03-18-2010, 02:49 PM   #5
aeipee13
DKDC
aeipee13's Avatar
Drives: Yarlet
Really Split?
(dick measuring info goes here)
aeipee13 is offline   Reply With Quote
Old 03-18-2010, 02:52 PM   #6
coffiend
coffiend's Avatar
Drives: 08 Black LB
^ haha. simple, yet effective.
Old 03-18-2010, 05:39 PM   #7
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
thank you guys and im starting to second guess the 15x8+0 rims cuz I dont want to have to blow money to pull and roll fenders and shit or have to have too much negative camber and have to replace tires once a year so i think ill be going with the 15x8+15 as it sounds like that wheel wont cause as many problems. and Im not going high offset or wide tires.
Old 03-18-2010, 07:11 PM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
15X8 + 20 is cheap.. and no herpeMAX XXR wheels.
Old 03-18-2010, 07:35 PM   #9
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
As claimed ealier in the thread:
Originally Posted by marlondog View Post
Like that guy with the blue Yaris with the Racing Dynamics and the 13mm hub spacers? He nearly took off his front fender doing autocross. I think he was running 30 offset wheels.
I don't want to seem as if I'm fueling the flame here, but if we're going to nip misinformation in the butt, I figured I'd point this out. Obviously Tamago since you've seen Enth's car run, you can chime in as to whether or not there's any issues with his fitment and auto-x runs?
Old 03-18-2010, 07:27 PM   #10
aeipee13
DKDC
aeipee13's Avatar
Drives: Yarlet
Adejong's "fitment" of 15X7 +35 front and +25 rear is perfect if you don't want to roll fenders. I run 15X7 +37 front, +24 rear without rolled fenders. If the my fronts were +35 it would be better looking. If the rear were +25 i don't think i would rub when i hit bumps.
I originally got deleted for calling out Split and his misinformation; i had to "simplify" my response. I guess admin actually read the post and are letting the people handle it now.
Old 03-18-2010, 07:35 PM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
it's kimona, who likes to keep us in the dark about what kimona considers "cookie cutter" fitment.
apparently it's a sore spot..
Old 03-18-2010, 09:40 PM   #12
1.5
Form>Function
1.5's Avatar
i have no idea what you guys are even talking about right now lol
Old 03-18-2010, 09:46 PM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
bottom line...
do what you have to do. 0 offset on an 8" wheel is gonna poke.
20 offset with 8" is gonna poke with a "proper" sized tire.
you're out to build a showqueen with stretched tires. why are you even on yarisworld asking questions? go to herra-frush dot cawm. stretch it, poke it, make it look stupiid, rub, ruin tires, all in the name of being herrafrush. .. . .
if you're sensible though, stick to 7" wide wheels and nothing lower than a 20 offset out back and 30 offset up front. enjoy being able to turn your car without destroying your fenders.
Old 03-19-2010, 05:28 AM   #14
AdeJong 03
"Stealth Runner"
AdeJong 03's Avatar
bottom line...
bingo.
im hoping to make these emotions fit with a +37 front +27 rear but if i want to go aggressive i may even try for a +32 +22
and i LOVE to turn. I have to take sunset blvd into town everyday and the whole damn road is basically a canyon. im not giving up handling.. thats for DAMN sure
Old 03-18-2010, 09:44 PM   #15
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Here's what I'm talking about. The front wheels have a +30 offset and the rears +17.
marlondog is offline   Reply With Quote
Old 03-18-2010, 10:30 PM   #16
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
I built a show queen. =P
For reference: -REAR- 15x8.5" +13 offset = 1.75" poke out of stock fender (no pull or roll)
Old 03-18-2010, 10:35 PM   #17
1.5
Form>Function
1.5's Avatar
yarisgui what are you running in the front?
Old 03-18-2010, 10:36 PM   #18
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
15x7.5 + 13 on front
edit: I realize now that you have a sedan.
Here is a picture of 15x8 on a sedan for reference, (I think +15 offset). You can see how much it pokes out the fender.
This isn't a Yaris, but another 4-door (EF Civic), with 15x8 +15 for reference.
I hope the pics help. Good luck on your build.
Word Association Black Yaris Off-topic / Other Cars / Everything else Discussions 7373 10-04-2011 10:43 PM
End of a decade? yaris-me Off-topic / Other Cars / Everything else Discussions 4 12-31-2009 12:12 PM
aftermarket front sway bar end links? jookybanana Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-08-2009 11:26 PM
Review: Adjustable Sway Bar End Links m911gt Performance Modifications 9 04-29-2009 09:25 AM
Questions, questions... littlecarlove Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-21-2006 01:42 PM
