Old 03-18-2010, 01:30 PM   #11
Split
Drives: 2008 Yaris Sedan
you guys are crazy.. you want to be running the HIGHEST offset possible because that's what this car is set-up for. If you're doing a 15x8, you'll want at least a +40 offset. if you run a high enough offset, you might even be able to get away with running a 225 width tire.. like a 225/45R15. Or if you want that stretched look you can run a 215/50R15. <- that's about as far as you can safely stretch onto a 15x8.
Split is offline   Reply With Quote
Word Association Black Yaris Off-topic / Other Cars / Everything else Discussions 7373 10-04-2011 10:43 PM
End of a decade? yaris-me Off-topic / Other Cars / Everything else Discussions 4 12-31-2009 12:12 PM
aftermarket front sway bar end links? jookybanana Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-08-2009 11:26 PM
Review: Adjustable Sway Bar End Links m911gt Performance Modifications 9 04-29-2009 09:25 AM
Questions, questions... littlecarlove Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-21-2006 01:42 PM
