#37 |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
you guys are crazy.. you want to be running the HIGHEST offset possible because that's what this car is set-up for. If you're doing a 15x8, you'll want at least a +40 offset. if you run a high enough offset, you might even be able to get away with running a 225 width tire.. like a 225/45R15. Or if you want that stretched look you can run a 215/50R15. <- that's about as far as you can safely stretch onto a 15x8.
#38 |
DKDC
Drives: Yarlet Join Date: Aug 2006
Really Split?
(dick measuring info goes here) |
#39 |
^ haha. simple, yet effective.
#40 | ||
Start another Oil Thread!
and i hate stretch.
you nailed it sir.
#41 | |
"Stealth Runner"
also, the op isnt actually asking for what the widest he can run is, he wants to know how aggressively he can make his wheels fit. |
#42 |
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
thank you guys and im starting to second guess the 15x8+0 rims cuz I dont want to have to blow money to pull and roll fenders and shit or have to have too much negative camber and have to replace tires once a year so i think ill be going with the 15x8+15 as it sounds like that wheel wont cause as many problems. and Im not going high offset or wide tires.
#43 | ||
you nailed it sir.
#44 | |
DKDC
I originally got deleted for calling out Split and his misinformation; i had to "simplify" my response. I guess admin actually read the post and are letting the people handle it now.
#45 |
★weeaboo★
As claimed ealier in the thread:
I don't want to seem as if I'm fueling the flame here, but if we're going to nip misinformation in the butt, I figured I'd point this out. Obviously Tamago since you've seen Enth's car run, you can chime in as to whether or not there's any issues with his fitment and auto-x runs? |
#46 | ||
it's kimona, who likes to keep us in the dark about what kimona considers "cookie cutter" fitment. apparently it's a sore spot..
you nailed it sir.
#47 |
Form>Function
i have no idea what you guys are even talking about right now lol
#48 |
Shut your fricken suck!!!
Here's what I'm talking about. The front wheels have a +30 offset and the rears +17.
#49 | |
bottom line...
do what you have to do. 0 offset on an 8" wheel is gonna poke. 20 offset with 8" is gonna poke with a "proper" sized tire. you're out to build a showqueen with stretched tires. why are you even on yarisworld asking questions? go to herra-frush dot cawm. stretch it, poke it, make it look stupiid, rub, ruin tires, all in the name of being herrafrush. .. . . if you're sensible though, stick to 7" wide wheels and nothing lower than a 20 offset out back and 30 offset up front. enjoy being able to turn your car without destroying your fenders.
you nailed it sir.
#50 |
やりすぎだ~
I built a show queen. =P
For reference: -REAR- 15x8.5" +13 offset = 1.75" poke out of stock fender (no pull or roll)
#51 |
Form>Function
yarisgui what are you running in the front?
#52 |
やりすぎだ~
15x7.5 + 13 on front
edit: I realize now that you have a sedan. Here is a picture of 15x8 on a sedan for reference, (I think +15 offset). You can see how much it pokes out the fender. ![]() ![]() This isn't a Yaris, but another 4-door (EF Civic), with 15x8 +15 for reference. ![]() ![]() I hope the pics help. Good luck on your build. Last edited by yarisugi; 03-19-2010 at 12:17 AM. |
#53 |
Form>Function
thanks yarisgui thats the exact wheel im getting thanks
#54 | |
AKA Samurai Racer
great job buddy ! |
| Word Association | Black Yaris | Off-topic / Other Cars / Everything else Discussions | 7373 | 10-04-2011 11:43 PM |
| End of a decade? | yaris-me | Off-topic / Other Cars / Everything else Discussions | 4 | 12-31-2009 01:12 PM |
| aftermarket front sway bar end links? | jookybanana | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 08-09-2009 12:26 AM |
| Review: Adjustable Sway Bar End Links | m911gt | Performance Modifications | 9 | 04-29-2009 10:25 AM |
| Questions, questions... | littlecarlove | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 10-21-2006 02:42 PM |
