diaper change in a yaris
Drives: 2009 multimode hatchback 5dr Join Date: Dec 2009
if the high-beams are working and the normal aren't,it can be a bad relay or a damaged fuse.perhaps even the connectors inside the handle you use to switch the lights to "normal" or "high" are damaged.
also,try another thing:leave the car operating on neutral and stationary ,and open the door while the lights are on "high". have you heard a beep of the warning system? if it's beeping, transfer the knob to "normal" and see what happens.i think this might give us a proper direction on how to solve this.
"there is no secret to the balance..you just have to feel the waves.." Heretics of dune. |
#2 | |
Drives: YARIS 2007 Join Date: Nov 2018
Checked door opening beep and it makes sound in high and low beams. Is there any relay for high beam? |
| ODD INTERIOR HEATING PROBLEM HELP NEEDED?! | fidgell | DIY / Maintenance / Service | 5 | 04-28-2010 01:17 PM |
| headlight problem | kenkyd | Cosmetic Modifications (Exterior/Interior) | 2 | 02-12-2010 06:55 PM |
| Can I get some help with a 2004 Kia Sorento headlight problem? | 33OH | Off-topic / Other Cars / Everything else Discussions | 14 | 04-01-2009 03:32 PM |
| Headlight Problem | slothman86 | General Yaris / Vitz Discussion | 7 | 10-24-2008 12:11 PM |
| Headlight Problem | sleuzze | General Yaris / Vitz Discussion | 1 | 09-03-2007 02:17 AM |
