Old 10-21-2008, 08:23 PM   #1
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
Headlight Problem
I have this problem where every 3 months I have a headlight blow out...It seems that every time I drive more than 200 miles at a time I loose a headlight. Can anyone provide some insight? This is getting expensive! I even use a small bit of bulb grease ever time I change them!
Old 10-21-2008, 08:33 PM   #2
yarisworld
Drives: 2008 yaris hatchback
Shouldn't this be a warrent issue if they go out so often.
I know they won't replace the bulb itself, but if there is a problem with the wiring???
yarisworld is offline   Reply With Quote
Old 10-21-2008, 09:36 PM   #3
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
... the brighter the light bulb the shorter the lifespan
That is simply NOT true. I've been running 100 W. halogen lights for the last 25 years (in vehicles that came stock with 55 w. bulbs) and never had a short lifespan problem.
A short life in any halogen light is most commonly caused by a bad ground, by low voltage, or by excessive vibration. Examine all connections for dirty or corroded connections. You'll need a volt/ohm meter to check things out electrically. They're cheap, at $15 for basic models, or borrow one.
Reddog99 is offline   Reply With Quote
Old 10-21-2008, 10:12 PM   #4
DFA
Compulsive Washer
DFA's Avatar
Drives: 08' AT Meteorite Metallic LB
Send a message via MSN to DFA
Maybe your/the mechanic's hands are always oily at the moment of bulb install? That's a pretty common bulb killer.
DFA is offline   Reply With Quote
Old 10-22-2008, 12:02 AM   #5
thatboyjer
thatboyjer's Avatar
Drives: 5spd 2007 Yaris LB
do you do any type of snorkeling in the yaris?
lol D:
99.9% of what goes on in my mind at work/school/home
[Debadged] [Tanabe DF210] [Limo Tint][17" Fondmetal Wheels] [Pioneer HU]
--:: Wishlist, PM me ::--
[SSK (WTB)] [Black Sand Pearl Eyelids (WTB)]
thatboyjer is offline   Reply With Quote
Old 10-23-2008, 08:33 PM   #6
slothman86
slothman86's Avatar
lol D:
good point...but not sooooo recently that it would be a culprit...I mean would contact with water blow it out right away? I always use gloves and bulb grease when I install...No, I don't put the grease on the bulb ...just the connector...I use silverstar ultras....maybe I'll try a different brand to see if that is the reason
Old 10-24-2008, 05:14 AM   #7
thatboyjer
thatboyjer's Avatar
o.o i didn't think you WERE actually snorkeling, holy jebus
Old 10-24-2008, 12:11 PM   #8
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
"bulb grease"??? I've never heard of that... Does the bulb manufacturer recommend it? Maybe try installation without it.
Gas pedal problem? Befuddled Performance Modifications 28 01-27-2010 09:55 AM
Headlight Problem sleuzze General Yaris / Vitz Discussion 1 09-03-2007 02:17 AM
Headlight fog elsteverino889 Cosmetic Modifications (Exterior/Interior) 2 03-28-2007 06:38 AM
HELP!! HID problem 07yaris_fe General Yaris / Vitz Discussion 2 11-20-2006 06:00 AM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
